TELL me what is going on CHECK ENGINE
Come out an hour later, start car, says ESP MALFUNCTION or something like that and car will only go 1mph, can not give it gas. Turn car off, try again, same thing. Go back inside. Come out about 30 min. later, try again. Seems fine, BUT check engine light is now on.
What do you think? Should I try to unplug the battery and see if it clears the code or take it in?
Thanks in advance,
Jason
Thanks in advance,
Jason
If it is an issue with the electronic throttle control, wheel speed sensor, etc, the techs should be able to see a code indicating a problem.
Could be a number of simple things ... but in my case, what you have described was a case of my torque convertor lock-up not disengaging. So, basically it was like trying to get the car rolling without any torque convertor action. Even more fun is that this will cause the supercharger to engage because of the high load, making the car fall on it's *** even more. If it happens again, the dead giveaway on this is that the RPM gain will be real "heavy" when the car is in park or neutral. Turning the car off and then on again will sometimes get the TC lock-up clutch to unstick.
I tried restarting the car a few times, but that didn't solve the problem. Just as I was about to call a tow truck, I tried starting it one last time and what do you know - the car is working perfect. The "ESP malfunction" message and CEL light are still on, but the car drives perfect. What the hell happened here? First its only driving 5mph in limp mode, then the next thing you know its back to normal. I drove home about 10 miles on the highway and no problems whatever (except the CEL). What the hell is going on?
P.S. This may sound crazy, but I got the power back right after I put the car in R and gave it some gas. I had to turn the car around, and fully expected it to still be in "limp" mode, but to my surpise it went in reverse like nothing was wrong. When I put it back in D, it was also working fine and I drove home. Not sure if putting in R actually solved the problem or if that was just a conicidence.
