K&N Air Filter E55 AMG
Old Jun 15, 2007 | 12:09 PM
por997s's Avatar
E55 AMG
Hi,
Can anyone confirm if the oil form the K&N air filter ruin the air flow mass meter?
Old Jun 15, 2007 | 12:11 PM
newton22's Avatar
BMW E39
It is found that K&Ns in E55s frequently drain blinker fluid and damages the transmission's triple flywheel setup.
In all seriousness, you do not have a MAF.
Old Jun 15, 2007 | 12:17 PM
Jrocket's Avatar
E55
W211's dont have mass air meters.
Old Jun 15, 2007 | 12:23 PM
oldgixxer's Avatar
'05 C55(sold)'05 E55(sold)'06 911C4S(sold)'06 ML350 '06 CLS55(sold),buncha slo bikes
You will be fine w the K&N's I had them on my 55.I actually have a brand new set sitting in the garage as well.Too bad they dont make them for the 63 yet
Old Jun 15, 2007 | 12:26 PM
por997s's Avatar
E55 AMG
I am also having an ECU & pulley upgrade this Thursday coming. Looking forward! ICP just been replaced under warranty.
Old Jun 15, 2007 | 12:28 PM
Jrocket's Avatar
E55
What brand of pulley and ecu tune?
Old Jun 15, 2007 | 12:29 PM
dsc's Avatar
dsc
2004 E55
WTF! This explains why people honk at me when I make a turn. Goodbye K&Ns. How do you refill the blinker fluid? Anything else I should know!? Thanks in advance.
Old Jun 15, 2007 | 12:32 PM
Jrocket's Avatar
E55
Ive made out a 2 sentence panthlet explaining everything you need to know,mail me 40 bucks...no wait,this is for an MB,make it 1000 bucks and I'll send you the info.
Old Jun 15, 2007 | 12:35 PM
dsc's Avatar
dsc
2004 E55
Do you take Pay Pal?
Old Jun 15, 2007 | 12:37 PM
Jrocket's Avatar
E55
Of course,and seeing how your a member of the board here,"We are doing a special for the month of June (2 days only)for 999 bucks"! Get in on this great forum discount.We are always here to help.
Old Jun 15, 2007 | 12:39 PM
por997s's Avatar
E55 AMG
Tuning is being carried out by DMS Automotive. Highly recommended by EVO Mag and a few of their customers.
http://www.dmsautomotive.com/
Old Jun 15, 2007 | 12:43 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
K&Ns=80 rwhp! only with synthetic DOT 8 blinker fluid
In all seriousness, you do have a MAP
Go with the greens
Who wants to wash filters
Old Jun 15, 2007 | 12:46 PM
dsc's Avatar
dsc
2004 E55
Thanks! Money sent, can't wait!
Old Jun 15, 2007 | 12:56 PM
Jrocket's Avatar
E55
MAP..What MAP?
Old Jun 15, 2007 | 01:20 PM
MAP..What MAP?
Mass Air Sensor measures volume of charge air in a natural aspirated engine.
Mass Air Pressure measures pressure of charge air in supercharged engines.
The E55 has MAS/MAF the E55K has MAP.
Old Jun 15, 2007 | 01:29 PM
por997s's Avatar
E55 AMG
Ok, now I am totally confused. So does the K&N screw up the MAP??
Old Jun 15, 2007 | 01:45 PM
IMHO, I want a good filter that keeps my supercharger clean, my intercooler clean and offer throw away convenience. K&Ns are far from my needs.
Do a search, here you will see many tests, draw your own conclusion.
Old Jun 15, 2007 | 05:51 PM
jangy's Avatar
2015 S212
Do draw your own conclusions.
I've run K&Ns since the early 80s and I was even a part of the early studies with the diesel engines.
The only lesson I learned is that cleaning and oiling them has to be done properly, but for the money I just treat them as disposable.
The green filters have issues of their own. The outer rim practically melts and collapses in our cars, which means you have NO filtering going on.
Draw your own conclusions.
Old Jun 15, 2007 | 05:58 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Actually, I believe it's called a MAF. Mass Air Flow meter. It measures the air flow in an engine. Its use is not just limited to normally aspirated engines.
Old Jun 15, 2007 | 07:13 PM
05VENOM's Avatar
old daily driver '07 E63(gone); new dd '14 750xi; 2013 Viper GTS
A mass air flow sensor(MAF) measures the actual volume of air that enters the throttle body(TB).
It does so by heating a filament(smalll wire which requires a certain current) located in the vane of the sensor. It heats up to a certain temp(dependent on the car). The amount of air needed to cool the wire down(this new current is recorded) to another desired temp is then converted by the ecu(the total change in current) and the proper fuel is added.
A manifold air pressure(MAP) sensor measures the density of the air and is usually less accurate. It is always easier to modify the intake on a MAS sensor since it measure the actual volume of air and can adsjust the fuel accordingly.
Old Jun 16, 2007 | 04:18 AM
Rafal's Avatar
2017 S63 Coupe Iridium Silver
They also give you pimples and shrink your *********...
Old Jun 16, 2007 | 09:00 AM
oldgixxer's Avatar
Thats just heresay,it's never been scientifically proven
Old Jun 16, 2007 | 11:18 AM
dsc's Avatar
dsc
2004 E55
Nooooooooooooo!
Old Jun 16, 2007 | 11:52 AM
Need a second opinion? K&N may give you huge *****.
Rachael Ray wants you to see her *****.
http://rachaelraysballs.ytmnd.com/
