C6 Z06 vs. Renntech E55 AMG..*Video*
"Z06 Vs. SLR; Before this race the SLR had slaughtered all it's competition including an SL65.....So I was pretty sure the same would happen to me....But no....to my big surprise the Z06 was faster than the SLR up to 250/260 km when I had to go into 5th gear.......And missed......so I lost the race....but only the last 100 meters or so due to my own fault...."
Also, just to make things clear. I dynoed at 450 rwhp on a Mustang dyno and then redynoed on a Dynojet and put down 462 rwhp.
We will just say the edited version with the camera in your car is the more accurate version..
Do keep in mind that I do have lighter tires in the back, a filter, and a short throw shifter. Not much, but before all that, I ran an 11.5 with a best trap of 126 mph. Also, rememmber that the E55's sweet spot was not really utilized in this race. I am guaranteeing that from a dig, it would be much a better race. The Z06 is an extremely difficult car to hook up on the street, but the PS2's do help a bit. On the other hand, I don't think a lot of people understand how quick the Z06 is. At a recent event from the M5 Boards, a Z06 pulled ahead of an SLR and stayed ahead all the way to 160 mph. All the Z06 had was a filter and a tune. My car made 460 rwhp and weighed in at 3080 lbs with a half tank of gas. With a driver mod, this car is very hard to beat. Some of you can call BS, and that is ok with me, because I would do the same if I never drove the Z06.
All in all, I had a great time and I will be looking forward to more races to share with you guys. Now, if I only had the video of me and the Sl65 I raced from a roll..definitely a fast car..
Yeah I think that little back window in the Z has a reverse binocular effect on recordings....lol
I was using your weight argument and you come back with "I do not know much about cars"?
We were discussing Physics and you were explaining why the Z06 walks away so easily. Then when turning to the Impala you add other parameters which also exsisted between the 55 and the Z06 yet no mention . You car destroyed a heavily modded 55. Great run, nothing wrong with your car , do you actually believe you would do that to all similarly modded 55's?
Rocket, your 1/4 mile time was better than the Z06 prior to your car breaking. Your car when running properly is likely a tad slower meaning 2-3 cars from a roll not 25-30 sorry but the result of this video shows a healthly Z06 destroying a 55 not performing so well. The torque of the 55 is what the poster leaves out of his original equation while he discusses, hp, weight, drag, lag and other physics torque is not mentioned and this certainly has a bit to do with a.
http://media.putfile.com/Mercedez-e5...orvette-C06-C6
what gear were you in ? Seems like he pulled hard after he shifted the first time. Were you shifting the car or d/s? Was esp on? Sorry for so many questions I am just having a hard time with this
Ok good race fellas,
guess I better just deal
Let me know brutha!
http://www.youtube.com/watch?v=6vjq5BJKR68
Just think about this fellas. Take the fastest stock E55 in the QT(?) and the fastest stock Z06(10.85@129) and compare them and you see why a Z06 is faster. Even the slower Z06s run high 11s @121.
Power to weight with gearing. It's pretty easy to see what happens. If you want an E55 that will outrun a Z06 from a roll then it needs a power to weight ratio that's close to equal. With the true weight of a Z06 being about 3080 and stock power being 460rwhp on most cars that leaves you with 6.69lb/hp. WIth an E55wieghing 4200/6.69 you would need the E55 to have about 627hp. So just drop an SLR engine in and you're set.
I agree, upon 1st glance from the front they appeared to be closer till I watched it a few times, the side angle shows a beating, but considering the CLS55 had 1 stage less, and the C6 Z06 was modded by Lingenfelter to 616hp I expected more of a win
