*** VRP Extreme Belt Wrap Kit ***
Roland
http://69.17.158.20/vrus/e55/extreme...nProcedure.doc
The catch can is working perfectly with no trouble at all. Nothing has changed about the install since I posted. If you have any questions on it let me know.
did your belt slip off at all? or was it right the first time?
hopefully my guys get the belt on today and to the dyno tonight, we will see.
At this point, it appears that my car has some other, pre-existing issues that are causing this condition, so there's no way that these results can be taken as a true representation of the parts I've installed. We are still running the Renntech tuning that was designed for headers and pulley, even though we have FAR eclipsed those mods. We're going to start from scratch and troubleshoot the car starting with the basics like a leakdown test, basic tuneup and sensor checks. At the same time, I'm desperately trying to find a source to write a custom tune for the car to see if we can cure some of these issues.
I'm sorry I couldn't report some great success, but it appears my car is determined not to cooperate. I'm sure once I get my issues sorted out, I'll be able to report back with much better news. Keep your fingers crossed for me!!
It depressing since here not one would be able to help ME nor I would be able to find right belt if there is any issues...
Victor have actually runned that kit on your car, did you try to intsall everything with ASP pullies ??? What is the situation right NOW ???
Any Updates anyone????
Roland
This one:
press on the link near the picture...The police is very angy with Streetracers now...they keep braking Moscow ring speed records...
I will post some vids of my freind E55 drifting later in city center later and then pics after he crashed...
https://mbworld.org/forums/w211-amg/200497-has-any-one-seen-russian-street-race.html
Ok what is DQR Durability , Quality & Reliability.
This Motor design has exceptional crankshaft main bearing Support. 4 cap screws vertical into the mainbearing cap , 1 screw on each side of the Crankcase = 2 more . total of 6 mainbearingcap attachment screws. BTW a screw is a screw , until it has a nut on it , then it becomes a BOLT
Just look at Finny's engine pics. 1st attachment.If you are worried about the additional side load on the engines front main bearing , Don't be. I would say that the load would be the same or less. Why ? with the additional contact of patch area , you would need less belt tension to maintain proper belt adhesion and keep slip to a minimum. The same goes for the Kompressor Clutch & belt wrap. Besides that! you got the engine accessory drive belt. Alt , A/C , P/S & water pump pulling the otherway. It has a wrap , routing ,you damn near need a GPS to get all its locations right
.Why does it have an additional add on barrel type tensioner , stop gap assurance for those really oversize crank pulleys that Make much more the stock Kompressor PSI.
Is there a down side to this kit. Well the belt idler pulley in between the Crank Pulley & the Kompressor pulley . It is taking the load. BUT. it is made of 6061-t6 billet alum stock, That is very good ( About the best) and its bearing is sized to handle twice the capacity of the stock belt tensioner pulley. I believe they got it covered !
Quality: Any Time some one uses 6060-t6 heat treated alum , Thats a good sign . Thats shown in the pulleys , & bushings. along with the brackets & pulley support Struts/ bars. As for the attachment hardware, I would have perferred the use of Hi Carbon steel,with black oxide coating. (Cheaper & very strong Grade 8) rolled threads , instead of Cut threads or 17-4 HT S.S. (very expensive). They did the right application on the Double polyvee idler pullies. That is a critical load & stress attachment point. The other 2 screws look to be off the shelf 305 S.S. Which can Move. if not locktited properly. My Guess is that they are not as critical, Odering matching hi-carbon steel bolts from Halo-Allen was cost prohibitive.
Reliability : The above all adds up to a very good solution to a MB design that would only satisfy 80% of its customers. The other 20% (Thats us) we have a good fix for our needs. I give it a 2 thumbs up!
___PTE___
I need to get all belt btw 54 and 56
so I want have any disapontment when installing this kit, cuase I wont find a right belt here for sure
Can you do some datalogging and capture boost, IAT and ignition advance.. Lets make sure the ECU isnt pulling a fast one on you.
Glad you got it all figured out.. I would like to get some more feedback on the burnt belt issue.. are you saying the 56" gave too much slack and was causing it to slip and burn up?
I am trying to figure out what problem your custom bracket solved... Was the Aux tensioner bracket a problem to install or did it not line up or something?
Would appreciate your feedback on this.
