Help: Programmable Mirror Function in Reverse
On my E63, the manual says I can program my passenger side mirror to dip when engaged in reverse. I've tried it a few times but it hasn't worked - and yes, I've checked that the mirror does not move when programming the initial position.
Has anyone else had success with this feature? I'm assuming this feature was available on the '07 and not a new feature for an '08.
TIA for any help on this. It may seems a small thing, but with the cost of these AMG wheels, I'm going to use all the tools available to avoid curbing them when parking!
Oh and it may help if you will post pics of your '08 E63, have you already?
Have you tried lowering the mirror? There's a limit to how far the mirror dips. If I adjust mine to high the mirror will not tilt while in reverse.
Didn't have time this weekend for the pix...wife's away for a few days and I'm in charge of our 15 months old! Have new respect for my wife as she's a SAHM and spends all day with our daughter on most days...
Will hopefully have a chance tomorrow when I'm working at home and the babysitter is here in the afternoon.
It should be active in the system as it is a specific entry featured in the '08 E-class OM.
That's interesting...didn't seen anything in the OM about that. Will try and see if that's the case too.
Hopefully this is not the case and a work around is available.
In the meantime I have programmed the correct reverse mirror position into seat position 3 and just hit it when I go into reverse then hit 1 again when I'm done. The upside is you can have both mirrors tilt this way so you can see the curb when parallel parking and save the nice rims.
Will use this method until I get the car into the shop and have it checked.
LOL! Yes, that was the FIRST thing I thought of!
