Porterfied Brake Pads - Annoying Rattle
Old Sep 6, 2007 | 12:09 AM
SleeperX's Avatar
E55
Has anyone using the Portfield RS4 brake pads notice an annoying rattle from the front end when you go over bumps. It appears that the brake pads are a little smaller than OEM and thus rattle in the calipers when you go over bumps. Any idea of how to fix this problem.
Old Sep 6, 2007 | 12:11 AM
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
Not yet...I'll let you know if I have the same problem.
Old Sep 6, 2007 | 12:15 AM
SleeperX's Avatar
E55
Are you getting the same brake pads. I just noticed on their website that it lists brake pads for the 2003 and 2004 E55, but not 2005. Could the calipers be differrny on 05 models.
Old Sep 6, 2007 | 12:20 AM
Jrocket's Avatar
E55
You better get that checked out,it doesnt sound right.I dont see how the pads could be lose in there,they should have a small amount of tension on them at all times.
Sounds more like somebody forgot too tighten a bolt somewhere.
Old Sep 6, 2007 | 12:32 AM
AMGfan's Avatar
[QUOTE=Jrocket;2398506]You better get that checked out,it doesnt sound right.I dont see how the pads could be lose in there,they should have a small amount of tension on them at all times.
Sounds more like somebody forgot too tighten a bolt somewhere.[/QUOTE
+1 on that...squeaking I've heard of from new pads, but not really a rattling sound...
Old Sep 6, 2007 | 12:36 AM
PlayboyDiddy's Avatar
2005 E500 AMG Sport
I had this same problem on my E500. I replaced my front OEM pads and the person whom did the job didn't hammer in the two pins that hold the brake pad onto the caliper and it rattled just as you described. One pin fell out and one was still attached. My dealer ended up replacing both pins for me and made sure to hammer them in properly.
Look at your brake calipers and there should be two little holes, one on each side at the top, make sure the pins are still in there, if so, hammer them in more and if not, get new ones ASAP.
Old Sep 6, 2007 | 12:44 AM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
OT: So how's your beast doing?
Old Sep 6, 2007 | 07:52 AM
SleeperX's Avatar
E55
Thanks everyone!!
Old Sep 6, 2007 | 10:37 AM
V12Godspeed's Avatar
Your worst nightmare...
+1...come one Bro, share...lol!
Old Sep 6, 2007 | 10:38 AM
SleeperX's Avatar
E55
Old Sep 6, 2007 | 11:58 AM
SleeperX's Avatar
E55
Spoke to a tech at Porterfield this morning. Apparently the rattling is not uncommon. It is due to the fact that the plate on the back of the brake pad is a different size than the OEM brake pad plate. He told me that it is nothing to worry about. If the noise is annoying he suggested putting a Bendix type adhesve between the brake pad plate and the calipers.
Old Sep 6, 2007 | 01:00 PM
Vic55's Avatar
Administrator
I have them on my 04 with no rattling? Maybe its because the part is specific for my 04 or because Evosport did a special mount. Check with Simon at Evo as he may be able to provide more insight on this.
Old Sep 6, 2007 | 01:02 PM
SleeperX's Avatar
E55
Thanks Vic. I think the rattling is coming from the pads and the calipers. I still have my stock calipers. Do you have new calipers? The evosport rotors are great. They are not the problem..
Old Sep 6, 2007 | 01:09 PM
AMGfan's Avatar
SleeperX...they are doing a test drive on the car tomorrow, which includes breaking in the pads and rotors. I'll PM you if I get the rattle and what if fix if any they find...
SleeperX's Avatar
E55
thanks
Old Sep 6, 2007 | 09:46 PM
JokerzWld's Avatar
2014 GL 350 on order
I had the same metallic rattle as well as no place to place my wear sensor probe so I took em off and sent em back. This was a year ago as I found it very concerning in my 100K beast-Joker
Old Sep 6, 2007 | 11:13 PM
Jrocket's Avatar
E55
I would of assumed this was the procedure on all pads? If the pads do not come with it already installed,then they should have come with the blue liquid that you apply to them,no?
$500.00 pads and they dont have this already applied to them? Amazing.
Old Sep 6, 2007 | 11:19 PM
jangy's Avatar
2015 S212
They sure don't and I like that. i like the sounds.
Old Sep 6, 2007 | 11:29 PM
Jrocket's Avatar
E55
You like the rattling and noise from the brakes?
Old Sep 6, 2007 | 11:35 PM
jangy's Avatar
2015 S212
Funny, huh? I do like the snap they make when I hit the brakes. Dunno why.
Old Sep 6, 2007 | 11:39 PM
Jrocket's Avatar
E55
Good enough for me....Brake noise,overheating radiators and dead batterys drive me completely insane.
Old Sep 6, 2007 | 11:42 PM
jangy's Avatar
2015 S212
You got me there. I hate nothing more than leaks, overheating, and dead batteries.
Old Sep 7, 2007 | 12:59 PM
Vic55's Avatar
Administrator
I am running stock calipers. I think Evo did some mods to the plates like you mentioned to get the noise to go away.
Old Sep 7, 2007 | 07:16 PM
AMGfan's Avatar
No report on brake pads...
they were just bleeding the brake lines when I left. I did get a pic of one of the painted calipers...
http://img214.imageshack.us/my.php?i...ict0457ws5.jpg
Old Sep 7, 2007 | 08:02 PM
SleeperX's Avatar
E55
Very nice!
