Best tire PSI for street driving E55/E63
E63, SL 550 Sport,C63 Coupe On the Way!!
I am at 38 all around was at 40 and even 42 but the tires squeal no matter what PSI i have in them around turns and shifting into gear i hate the Sport contact 2's but is this the nature of these tires?
What PSI are you guys running?
E63,,,not any more,,,BMW X5 50i
I am 41/45 --That is according to the tire. I have tried other settings, but the one specified by Conti, is the one I will stick with...until the PS2's come on!!
for all you running under 40 and in the low 30's dont you think thats too low? It sure must affect the handling and you must hear even more tire squeal.
2015 S212
Why more? It makes for a larger contact patch and more flex in the ribs. That allows the sidewalls to flex and extend the outer diameter while under power. Haven't you seen all the drag racers? They have low pressure and the cars just stand up when they pin it.
I use tire pressure to balance the car out sometimes. I crank the rears up to about 45 if the car is pushing and it causes the rears to come out sooner.
Bead-lock wheels are a must in a lot of Motor-sports.
06 SL600
MB says to run 36 all around for under 100MPH. I typically run 38 (front) 40 (rear). I'm using Goodyear F1 GS D3's as a compromise tire. The pressure MB recommends for over 100 is too high for my taste. I think it is 44 (front) 49 (rear). No doubt that those pressures are safe for cruising at up to the 186MPH that the 030 is governed to. I get a little squealing when pushing on corners. You may want to try something a tad higher than I am running but i would recommend "staggered" pressures. Good luck.
I run 36 up front with my 245/35/19 Nitto 555 and 30 out back with 275/30/19 Nitto 555 I hook up pretty good with TC on but they still break loose around 35mph. I have been driving around with the TC off to learn more about how the car will react under different situations.
JJ
JJ
Help me understand...........why have lower air pressure than what is recomended by the tire manufacturer, or MB? I always thought for optimal performance and tire life, follow what the manufacturer says. I do know that lower/higher pressure than what is recomeded can cause serious problems...so am I missing something,,,,,,like to know.!!!
'06 E55, '05 SLK55, a few others
