Anyone have any issues with ASP pulley function??
Old 09-11-2007, 12:37 AM
LTHL VPR's Avatar
Just curious if anyone has had any problems/issues with the ASP pulley? Not with regard to heat, etc. but with regard to quality, durability, longevity. I have used them many times in the past for custom pulleys without any issues I can remember, but heard from a MB tuner that they were prone to breaking and causing damage when they fly off. Is this true? Never heard of this with the MB world guys.
Old 09-11-2007, 12:59 AM
DFW01E55's Avatar
'14 ML BT
Originally Posted by LTHL VPR
... but heard from a MB tuner that they were prone to breaking and causing damage when they fly off. ...
You heard this from a competitor of ASP?
I've had an ASP pulley for 10 months now, the biggest problem that I have is replacing PS2's at a cost of $315 each after only 4,800 miles.
The pleasure factor for those 4,800 miles was very high ... very high indeed.
Anyone with damage from a broken ASP pulley?
Old 09-11-2007, 02:10 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
someone's asp pulley was eating belts but that's the worst (and only) problem i've heard from them. i quite enjoy mine!
Old 09-11-2007, 02:14 PM
LTHL VPR's Avatar
Any other stories out there? If it was eating belts, it was probably because it was not press fit on all the way (not installed properly), or maybe it was the wrong pulley for the application.
Old 09-11-2007, 02:19 PM
Jrocket's Avatar
E55
Use the search button here,you'll find plenty of positive talk about the ASP pulley,a side from it being ugly of course.
Old 09-11-2007, 02:43 PM
V12Godspeed's Avatar
Your worst nightmare...
10k miles here, by far the best bang for the buck.....
Old 09-11-2007, 02:44 PM
SteveFox's Avatar
Bentley Flying Spur, CL550
I LOVE mine by the way. No issues at all.
Old 09-12-2007, 07:11 PM
TopGun32's Avatar
no issues..
engine start up is a bit rougher.. I'm not sure why.. but once the car is warm is no issue.
belt slippage will be a problem.
but after the dealer replaced my kompressor clutch, its less than before.
belts do wear off a bit sooner.
without any cooling mods, its probably not a good idea.
I finally installed the johnson pump and it actually lets me keep boost a bit more without the ECU dialing back. The real way to deal with high ITA temps will be in a bigger IC core.
best $800 I have spent on this car...and don't need to mess with the ECU.
Old 09-12-2007, 07:59 PM
zdkdeeier493's Avatar
Old 09-14-2007, 04:46 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, LRD4 HSE, R107 280SL
Well mine still intact although got quite a bit of rust on it ... which I wd40's so its ok-ish now ... you getting what you paying for here nothing more ... build quality is only barely acceptable for this application in my opinion.
Bang for the buck cannot be beat tho...
Quick Reply: Anyone have any issues with ASP pulley function??
