VRUS TB or Renn Headers with 178 pulley???
Old Sep 17, 2007 | 12:08 AM
aganzon's Avatar
W211 E55 AMG
I've decided to get the Evotech 178 pulley. But I wanted to know if I should get the TB or the Renn headers. Which do you guys think combine better with the pulley? TIA
I want to give Adam @ EuroElites a prop for the great stuff he's doing!
Old Sep 17, 2007 | 12:15 AM
ROCKETW19's Avatar
06 EuroElites E55
first off i love the sig.
i wouldnt get the renn headers i would get the evo headers they are alot cheaper and will give the same hp. TB is my favorit mod but id get that after the headers. good luck and good choice with adam.
Old Sep 17, 2007 | 12:19 AM
bfnnrgn's Avatar
SL65
Might want to invest in a cooling mod instead.
Old Sep 17, 2007 | 01:06 AM
aganzon's Avatar
W211 E55 AMG
Rocket: (OT) Thanks for the sig compliment. As an owner of a very loving pitbull, Vick makes me puke at the thought of the cruelty he and his gang has committed. If treated well, pitbulls are super loyal and are loving pets. I'm glad he's going to lose triple digit millions.
Thanks for the evo headers advice. I will seriously consider it and ask Adam. They are both direct replacements of the stock exhaust manifold and neither cause CELs. According to a trustworthy source here, the evo gains 20-25 rwhp/tq vice 15-20 rwhp/tq on the Renn.
Thanks again.
Old Sep 17, 2007 | 01:10 AM
aganzon's Avatar
W211 E55 AMG
yeah. 2nd phase. I don't do any long track runs right now.
Old Sep 17, 2007 | 01:22 AM
aganzon's Avatar
W211 E55 AMG
VRUS and Jangy?
VRUS and Jangy: I know you're out there. Would love to hear your opinion as well.
Old Sep 17, 2007 | 01:23 AM
ROCKETW19's Avatar
06 EuroElites E55
yes post up you pit! i have a lil girl 51lbs she was the runt and i got here from my bro who breeds them and couldnt sell her. you cant tell in the picture but she has big quads.
Attached Thumbnails VRUS TB or Renn Headers with 178 pulley???-camerapix-002.jpg
Old Sep 17, 2007 | 01:38 AM
aganzon's Avatar
W211 E55 AMG
here you go: Bowser
Here you go. His name is bowser. He enjoys M&Ms.
Attached Thumbnails VRUS TB or Renn Headers with 178 pulley???-bowser.jpg   VRUS TB or Renn Headers with 178 pulley???-bowser2.jpg
Old Sep 17, 2007 | 02:04 AM
ROCKETW19's Avatar
06 EuroElites E55
nice bro, the wife wants him!
Old Sep 17, 2007 | 02:06 AM
RoydRage's Avatar
SL55
Lightbulb Headers
I would get the headers... Reason being the pulley, and the throttle body are both doing the same thing... Getting more fuel into the motor, the pulley by increasing boost, and the the TB by increasing capacity.
When you put more air in, you need to help get it out, hense the headers...
The other poster is correct too... You will need the IC mod when you increase boost with the pulley, you will be increasing the air pressure, when you compress air it gets Hot... It will heat the IAT's like Hell with that big pulley... You might not make a 1/4mi without the supercharger shutting down.
With just my software mod... I can definately feel that after I jump on the car a few times... It's never as fast as the first time...
So I'm planning to do the RT 168mm Gel pulley, but not before installing the Johnson CM30 pump... And a better, or extra heat exchanger next.
Best,
RoydRage
Old Sep 17, 2007 | 03:20 AM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
Best,
RoydRage
Main issue with 55k motors is the heat from reading this forum. You are getting an evotech pulley a big one, which means allot more heat. Stock cars have been complaining about pump failing etc. So cooling and pulley seem like a good combo. but headers to let it out hmm
Old Sep 17, 2007 | 06:50 AM
E55 RUSS's Avatar
E55K
Header 1st...I would reccomend Kleemanns one, without Primary cats...You get extra 10HP at the wheels with them...
Old Sep 17, 2007 | 11:28 AM
jangy's Avatar
2015 S212
Somebody call for me? Hehe!!
Well, you know it is tough for me to pick a RennTech mod over another, but I'll keep it objective for you. My take on getting juice from these rides is to get more air in and to cool off the front end. I think the exhaust side is fairly decent, and in all honesty all the shorty headers are simply a slight difference. Don't get me wrong, since I will be getting a set of Charle's (for $1500) as soon as they are done. BUT, I do think that a 80TB swap is an absolute must to see any of the gains that you can get from other mods. I say hook up the '07 SL TB, since it runs for about $1500 in parts (retail) and about 5 hours for install. Ask Adam about it. i'm sure he can hook you up.
Pulley: I think you made a nice choice. I am still on the fence with this one. It is a critical component and I like the size. I don't like the fact that it is not a fluid dampened one, but the quality is there with EvoTech.
Are you planning any ECU mods at this point? What year car? If it is an '06, I wouldn't bother until you have done more work.
Headers: I don't like either EVO's or RennTech's. The EVO ones are a compromise in quality and the RennTech ones are just not much different than a manifold. I've also heard and seen some data that shows the gains with the RT unit to be minimal, at best. It wasn't the most controlled study for my taste, but it is what it is. I was planning to do a nice comparison, but I'm done caring if RennTech products are worthwhile. There are a few guys out there working on alternative headers for much better prices.
ECU: If you do get the TB, I think you will notice the difference. Run a dyno and see if the thing is finally not running rich. If thne A/F has actually raised, then you will want to get a tune. The pulley alone won't need it. Mine runs pig rich and I think most of these do. It is actually a safer setup to run rich, but it isn't the most efficient.
Old Sep 17, 2007 | 12:20 PM
aganzon's Avatar
W211 E55 AMG
My thought about getting the TB was to "match" or provide a bigger path for the increased amount of air being sucked in by the bigger pulley. Do you think the stock TB will be efficient enough?
RoydRage wrote>
My thought as well...
RoydRage wrote>
Old Sep 17, 2007 | 12:27 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
I say headers. Can't argue with DJE55's numbers with simple K1 and header setup. Course his car was a freak of nature, but still.
Cooling will be big issue quickly though. Gotta get that Johnson in there minimum. It's just a few hundred bucks and not so tough install. I ran with just Johnson for quite awhile and it got me by.
Old Sep 17, 2007 | 12:44 PM
aganzon's Avatar
W211 E55 AMG
Thanks for the thorough feedback! I hear you about the lack of dampening. Like you said, it's a pretty good quality. The pulley kit includes the ECU mods. I have an 03. Gains from a 03 with ECU mod?
Old Sep 17, 2007 | 12:46 PM
aganzon's Avatar
W211 E55 AMG
Thanks! Yeah! I like the Klee's as well. They are pretty nice. More HP/TQ. But I didn't want to cut.
Old Sep 17, 2007 | 01:25 PM
jangy's Avatar
2015 S212
Yup, you are good with an '03. The gains are minimal, since it is just a pulley, but you will love it once you add the TB.
Another reason to go with Evotech is to have Oliver do your ECU tune. He is about as close to a custom job as you can get.
Old Sep 17, 2007 | 01:26 PM
jangy's Avatar
2015 S212
Don't get into cutting for an added 10hp. That is for if you go hardcore.
Old Sep 17, 2007 | 01:52 PM
aganzon's Avatar
W211 E55 AMG
Another thing I like about the TB approach, same or similar HP/TQ gains of the headers but it keeps the sleeper exhaust note.
Oliver is the man, i hear! Have to make sure Oliver works on the tuning.
Old Sep 17, 2007 | 01:53 PM
aganzon's Avatar
W211 E55 AMG
Agreed. Definitely not hardcore here.
Old Sep 17, 2007 | 02:04 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
tb will not give you the same peak hp gains as a good set of headers...but the performance gains are close. also headers alone won't change your exhaust note so don't worry about that. actually, you could run these cars with open headers and still have a sleeper.
Old Sep 17, 2007 | 02:09 PM
aganzon's Avatar
W211 E55 AMG
If I go with the TBs, I was also thinking of insulating/wrapping the plastic intake tubes to keep the heat down.
Old Sep 17, 2007 | 02:26 PM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
Old Sep 17, 2007 | 04:06 PM
chiromikey's Avatar
people have tried it but i doubt there's any measureable benefit. if anything needs to be insulated it's the airbox covers since they're cast aluminum. however, when you insulate anything you also have to consider other aspects. insulation works to keep heat out initially but once heat soaked it does just the opposite...it keeps heat in by preventing the parts to cool properly. so unless you can cool down after every run and don't do any prolonged driving it may help.
there's no magic pill or quick fix for reducing iat's. forget all the goofy little things and put the money towards a quality i/c pump and heat exchanger kit.
