Help! Need Service invoice's from your Super Charger repalce or Super Charger CHIRP!
Old Sep 28, 2007 | 04:42 PM
draggingcents2's Avatar
2005 E55
Please fax or email me your dealer service invoice from your CHIRP fix. My dealer Caliber Motors says there is no fix for it. I want to show him what other dealers are doing about the chirp. 714-388-3770 fax or DarrylLoomis@yahoo.com
Old Sep 28, 2007 | 09:11 PM
2005 E55
I got car back today. They said Chirping noise is normal no fix?? But my car bucks and kicks when you ease into it. Even with the new belts it chirps. What is the chirp fix? I faxed the dealer the 1 service invoice that was posted but they said that was some thing different. I also print out the thread about this and they read it all. They will and want to help but they do not know what the fix is. Look how good they are, They replaced all this under warrenty. Car looks and runs nice. Except for the rough engage and the chirp.
1) Cracked engine mounts.
2) New upper ball joint
3) New Poly V- fan belt
4) new Engine and Super charger replaced
5) new driver side arm rest
6) new upper trim panel (it bubbled)
7) Tensioner pulley was checked
8) Left lower steering knuckle
9) Front engine mounts left and right
10) Sway bar was found loose and replaced. New sway bar brackets and lube.
11) New right front headrest switch
12) A/C cleaned out, disinfected, deoderized new filters
13) new evaporator temp. sensor
1.6 hours of road testing with with chassis ear hooked up. They removed the subframe they found the left front engine mount was loose. They inspected it and it was broke and seperated although mount was not leaking. Then they also replaced the right side because of reduced clearance.
I heard clicking noise and they did to but could not find.
Old Sep 28, 2007 | 09:14 PM
2005 E55
Old Sep 28, 2007 | 10:04 PM
Timeless's Avatar
2005 E55 ///AMG
I can tell you my car is much much smoother from a start with the fix I posted for you already. Have not heard a chirp....yet.
Old Sep 29, 2007 | 06:32 PM
2005 E55
Thank you for your help. They said yours was for a noise in the clutch????
Old Sep 29, 2007 | 08:29 PM
J 2OOI's Avatar
2012 JDM
My stealer replaced my supercharger clutch after I complained twice. For the first complaint they replaced the belts, but the chirp lived on. I complained again and they replaced the supercharger clutch I think. I have the work order with me, I can fax it to you if you'd like.
Old Sep 29, 2007 | 08:43 PM
yeahdickey's Avatar
E55
J 2OOI & draggingcents2
can you guys post your work order for what they replaced?
sh*t .. looks like all they did for me was replace the pulley? .. i dont think my dealership replaced the clutch ... this is my work order from thursday:
__________________________________________________ _
A.) Cust States Super Charger Chirps When Driving (See TSB)
Cause: 11
094730 Compressor Pulley, Replace (N/C)
333 WLPC
1 113-090-00-44 Coupling (N/C)
41253 Noisy Bearing M Fail Replace Pulley --- DTC
Read Out No Codes Found in ME Trace and Locate Noise For Repair Replace
Super Charger Pulley Adjust Clearance .38mm As Per P-B-09.50/25, Date 01/31/2005.
__________________________________________________ __
Old Sep 29, 2007 | 08:49 PM
J 2OOI's Avatar
2012 JDM
Here you go man.
Attached Thumbnails Help! Need Service invoice's from your Super Charger repalce or Super Charger CHIRP!-sc-clutch.jpg
Old Sep 29, 2007 | 08:54 PM
yeahdickey's Avatar
E55
ohh cool .. same as mine i think? .. (see my post above)
i guess TSB P-B-09.50/25 is what people need to tell there dealership
Old Sep 29, 2007 | 10:22 PM
2005 E55
Thank you but please keep them coming. The more I have the better it gets. This time I am going to take car to another dealership and see what they say.
