What should I Mod on '05 E55!?
https://mbworld.org/forums/showthrea...&highlight=mod
Any pics? Give me a call on Monday, and i shall walk you through on Evotech products.
Jangy, Believe it or not, I drive the car about once a week to work and back (and 1mile roundtrip to the gym few times aweek). I wanna boost the HP abit without dumping a crapload of money. I'm wary of the underdrive pulley mod as it made my car run way too hot in PHX on my Mustang, although it did provide a noticeable pwr increase. Would love some new shiny headers but too pricey at this time. Any data on chipping it out? Also, I wanna put an XM (not Sirius) receiver in the car.... New airbox with KN's and larger dia. throttle body might be an easy (and cheaper) mod. I read a blog about dropping the front end 8/10 " by installing washers on the airmatic assembly...
Thanks for the input!
If your looking for a cheap and low daollar mod then the ASP pulley is your only choice.No ecu tune needed.ECU tune alone is around 1500.00.ECu tune alone is not worth the money.
Pulley is best bang for buck. ECU alone won't give enough. Another potential start is the TB, if you are weary of heat soak.
Same issue on these, but there are cooling solutions that help
A few people are working on sets for about $1500, so stay tuned.
This will be debated to both extremes. I do not believe that chipping alone will do much at all (compared to the $$).
Any stereo shop can do that, but it will NOT integrate with the OEM setup. You just tap it in.
I love K&Ns, but none of the airboxes have shown any power gains.
Larger dia. throttle body might be an easy (and cheaper) mod.
BINGO!! I'm about to do that and I have no other mods, yet. Parts are about $1200 and it takes 3-5 hours of labor.
Tis very true, but read up on it before you decide which way to go. There are 3 options: The washers, STAR, and ELM. You basically get what you pay for, so your choice. I have tried all three and love the ELM.
I would do the TB myself but not mess with the headers... above my paygrade on such an esoteric engine. I'll research the TB brands.
Jangy, what do I have to do to integrate the XM into my system, if possible? The Dealer wanted way too much money for both the receiver and the install. Thanks again for your input, Ken.
