SLR Pistons & Rods
I compared the SLR, CLK-DTM and E55 at one point and have all this data somewhere..
I have an iron sleeve 5.7L forged bottom end solution that is almost ready for primetime..
I figured that with a bunch of cars getting up there in mileage, and people cracking pistons due to detonation, something like this would come in handy.I'll have pics to show soon..
How is it going? Do you think it is safe to sleeve these cars with as much HP as they are putting out? How much is this bottom end solution? I assume it will include pistons, rods, etc. And of course the question that is always the most important to me. WHEN CAN I GET IT IN MY HANDS?
All the LS1/LS2/LS7 GM motors that the tuners are building up with TT kits are running Iron sleeves also.. The great thing with the sleeves is that should you damage one, you simply replace that one sleeve and you are good to go. Of course on the MB block I believe Ted & I are both pioneering this because I dont know of anyone else that will have a sleeved 55 block.
My engine builder recommended it so I am comfortable with the setup.
Not sure on pricing because I am waiting on the pistons. The bottom end will either be a shortblock preassembled, or can be purchased in pieces as needed. I am using stock crank.. Rods are being reviewed.. They tell me there is no point in making new ones because the stock ones are strong and they left nothing on the table for them to be modified so no point in recreating another set.
I will be fly-cutting pistons so I can get more aggressive with the cam selection..
Its going to be a few weeks before I can offer anything.. I want to install and run it on the dyno first and see what kind of power it makes.
I am with you on this...if TT kit will be affordable I will go this route as well...
Then may be need to get something like Skyline 4wd system which will make our car actually drivable, cause rightnow I can launch or do rolling start at 1gear...either ESP cut off all the power or I go sideways
Did you ever thought about it ???...our MKB dealer here made CL55 and CLS55 620HP + into 4 matic cars...You wont believe it but CLS 55 off the line smokes all Skykine and Evos...
P.S. I did want to mention that the Mahle stck pistons and rods that do come in the AMG blck are very strong and don't need to be upgraded or replaced like you said ,unless damaged.
Displacement is calculated by taking the cylinder bore x piston stroke. While displacement is almost always king, there are limitations when taking an existing block and increasing it's displacement. 10% is roughly the most you'll see from most engines, and this is almost always primarily a result of boring (for a number of reasons). However, that has limitations - such as the cylinder walls, spacing between cylinders, nikasil coatings, compromising integrity, etc.
It gets really complicated really quickly, and each block is different. Do not automatically assume that you should always increase displacement by as much as is physically possible because doing that has it's drawbacks.
On a slight offset from this discussion, and some will disagree with me, I find it somewhat preemptive that people are already talking about building blocks and spending significant dollars doing so without knowing what the physical limits of the stock block are. I'm not talking about theoretical limits, I'm talking about actual limits. Maybe no one wants to sacrifice losing a block but it seems with all this investment going into pioneering the strengthening process it would be somewhat conducive to future development if there was a point at which we could say that one needs to start thinking about a built block. I would be extremely, extremely surprised if this block couldn't take 800hp if not more from the factory. I don't think many people are going to need to touch their blocks, especially if we have good rods and a good crank. Pistons are often lost as a result of poor tuning and poor combution, not massive horsepower - although yes, pistons have their limits of power as well.
My $.02
-m
Hope this helps.
-m
Thank you Marcus...Vaeth has 5.8 stroker for E55...
I would be intresting in poricing as well and most important the POWER gains...
My $.02
-m
As I have highlighted Marcus comments. Your .02 is worth a million dollars and exactly what I preach!
Marcus you have hit the nail right on the head!
I would also be willing to build a twin turbo with a 100% stock long block. The stock assembly will make over 750 rwhp before it becomes a problem.
Give me a good crank and the longest rod possible anyday of the week.
The fact that you can run 130mph in high 10 seconds in 90+ degree weather and 90+ humidty using NOS and low 11's at over 120mph just motor is a testament to how well tuned your car is and how great a job MB AMG has done with the STOCk internals of the 5.5L motor.
Like we have all said on Mon as well,nothing beats ,custom dyno tuning and it seems like the AMG's agree and love this as well.
A car can only be made more reliable if it's making major HP with custom dyno tuning regardless of the cost IMOP.
With the way you run your car (like a Madman) - the question is going to be how much do you have to spend?
For the typical street driver, 800hp is easily achieve on stock internals, but for the guy who's topping out his car on a weekly basis... that's why MB/AMG over-engineered the blocks to begin with
-m
