One Step Colder Spark Plugs
https://mbworld.org/forums/w211-amg/214432-reducing-engine-heat.html
I had them on two of my previous turbocharged vehicles and they worked well.
Thoughts??
Also how does the dual sparkplug thing come into it ? Why dual to start with ?
There is greater chance of detonation and wear on a hot plug under higher cylinder temps than for which it was designed. A cooler plug is almost always safer ... but you cannot go too cold or the sparkplug will start fouling up, and the spark will degrade....
So typically if you add decent power to your motor via mods its safer to go with a one step cooler plug than OEM
This is how I understand it ...
