New Custom Front Mount IC HE (2003 E55)
#151
excluding prolongued test runs and drags, when will you begin perceiving a difference? for example, considering a fast drive along an uphill route (you, know, I live along the MilleMiglia route ..) , with high rews in 2nd and max 3rd gear
#152
2005 E55
As far as feeling a difference...my butt dyno is not that sensitive. Both with the stock HE and Code3 HE felt fast thanks to the 55k engine and the ASP pulley. Which one felt stronger? I really can’t say. I was too concentrating on the road ahead and looking out for cops. Of course, the data logging runs weren't done by hours of road testing, but the numbers would give you an idea on how the Code3 HE performs compares to the stock one.
By the way, I don’t drive in manual mode. I just leave it in S and stomp on it. I would assume it dropped to 2nd gear at ~50-60mph? and it will quicky shift into the next gear.
#153
I am not sure what you are asking...
It's clear that you didn't test it for enough time, yet ..
I mean: need not any data . I was asking only for your personal idea, sensation .. about when, in what practical situation, after how long a run, this better performing HE would let you feel it is concretely "helping" the 55K to perform at its best.
#155
2005 E55
you intended it correctly, indeed.
#156
all I can say....
before.. I would notice the power of the ASP only in the morning and a few hard runs.
after that.. I would need to be shifting often to get to the power band.
Now.. this thing in the morning feels like a enless torque beast (like a 600 biturbo)
and on the freeway.. power is always avaiable. Just 1 shift away from blast off.. or one deep mash of the pedal.
The 5sp auto still not as responsive.... at times. but power is always there.
If you plan to take on a few foes.. suggest you drive around town in 3rd and 4th on the freeway. This way you are always ready for battle..
#157
all I can say....
sorry, could you explain better ..
I 'll try to explain better my query in previous post, too.
What is not finally clear to me is the following commonly agreed consideration:
" the up-graded Heat Exchanger is considered a "second best" option with respect to the "Top Mounted I/C" mod."
A second best for what, if not PERFORMANCE ? .. I mean Performance in absolute terms . The reasoning that a more efficient HE will better allow continuing performance under hard conditions .. etc, is already clear and need not to be discussed further.
#158
The ultimate objective is to reduce/maintain IATs, while increasing boost.
By reducing IAT's ECU won't pull timiing. ECU also looks pretty agressive in pulling timing even early on when IAT's are marginally above ambient as per Alberts post. Tuners obviously toy with this map and dial in more advance at each point in the matrix.
It seems the ECU does NOT pull timing based on knock sensor? (If so where is it?)
It pulls timing based off a map of IAT, boost, load, coolant temp etc and from this calc's how much it should pull timing. The main culprit is IAT's. This methodology is not ideal as its independant of the fuel octane being used, and if so, the stock tune will be very mild to allow for dodgy fuel.
#159
indeed I wrongly underrate the importance of IAT in determining timing pull (btw, it means "retard", yes?)
and take this occasion to clarify the following:
... then, if top mounted I/C 's goal is similar, where from comes higher boost in SLR? indeed not from ASP!
It seems the ECU does NOT pull timing based on knock sensor?- for sure. but Knocking .. isn't mainly dependant on fuel octane and compression ratio? ... indeed, in SLR they lowered compr from 9:1 (as is for AMGs 55) to 8.8:1.
don't agree with this: .. higher fuel octane and its anti-detonating power, allows for an higher knocking point and therefore helps avoiding timing pull to take place or, in other words, allows for a more advanced timing map
#160
Believe me I hope someone would tell me this is BS - but without a knock sensor I dont know how the ECU would know it could advance timing when fuel is of a higher octane...
#162
Ciao Dyno - I think you misunderstand what I am saying. Higher octane is good, but our cars have to be tuned to utilise the benefit. Other cars with knock sensors will automatically advance timing to the knock detection point and then retard timing slightly hovering just on optimum. Our cars just read a bunch of inputs, go to a table and say - retard x degress. That seems will apply if you got 100 octane or 80.
are you saying that our cars do not have the knock sensor?! ... I didn't look in detail, but I can tell you for sure that even using 98 octane Agip instead of basic 95, I do really perceive the difference !!
Therefore, sorry, do not agree with this:
ps: .. it is this same kind of "perception" that I was trying to understand whether is going to happen or not by installing upgraded HE
#163
I hope you are right but the write-up from WIS that albert posted seemed to indicate no knock sensor present.... I really hope there is tho...
#164
£1.10 ish ... I only use Optimax here.
Yeah got those dimensions but what are the OEM dimenions? Just wonder where the extra fluid capacity is derived from.
#169
C32, Cobra, 700hp Vespa
Ok, the results are in. Stock pump adequate? Yes, Johnson pump better? Yes!
Sunday we took Marks car out again. We had originally tested the Johnson pump, but the numbers were no better than stock. Although, we certainly expected to see some difference. We wrote it off to an anomaly, and decided I would come back to get some more test results. These results definitely show that the Johnson pump works very well in conjunction with our upgraded heat exchanger.
Ambient temp: 60°
Three total runs. First two were 3 minutes apart, last one was 6 minutes later (had to turn around on the freeway ). The first run was the only run that we were able to get to 120mph. I told Mark I had other plans that day, so jail would probably spoil it The other two runs were to 112mph. As you can see, the results are more impressive. The highest run was 132°, followed by 121° and 123°, with cruising temps dropping back down to 13° above ambient. We were extremely pleased with these results, as they certainly surpass our last numbers. Here is the graph of the runs.
Ambient temp: 60°
