need help >3000rpm loosing power
Old Nov 1, 2007 | 12:05 PM
eckstiga's Avatar
CLS55 IWC, E55, S65
Unhappy need help >3000rpm loosing power
it seems that my E55 loosing power when over 3000rpm, i've checked with the dealer but they said nothing wrong with the car...any have this problem? help?
thanks
Old Nov 1, 2007 | 12:24 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
mm thats a new one ... thats right in the middle of the torque peak band ... wierd ....
Fuel lines clean? Injectors? spark plugs?
Traction control ??
Old Nov 1, 2007 | 12:34 PM
eckstiga's Avatar
CLS55 IWC, E55, S65
everything is checked no fault from STAR Diagnose.
Old Nov 1, 2007 | 01:26 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Worth a shot swapping out belt on the supercharger.
Literally takes 60 secs and can make a world of difference sometimes.
Just my 2 cents.
edit****intercooler pump rarely ever shows on STAR. It's become a little comical here (every loss is blamed on pump) but it is worth looking at as well.
Old Nov 1, 2007 | 03:38 PM
TopGun32's Avatar
3k? you sure?
the kompressor is actived around 1800 rpms or so.. very close to 2000 rpms.
by 3k. you have full torque....
does thing happen after being in traffic for a long time.. maybe its heat soak.. aka: high IAT temps .. bad IC pump
you will loose some power if the car is running in hot weather for a long time.. and you are running stock pump and intercooler.. that's just the price we pay for having a FI engine.
Old Nov 1, 2007 | 05:44 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Does the car lose power completely or just seem weaker. I think the IC pump failure just shuts down the supercharger, but the car should still feel and operate like you're driving an E500 (at least). If it loses power completely and feels like it is bogging, then maybe something else more serious
Old Nov 1, 2007 | 06:19 PM
tommy25000's Avatar
2005 E55
mine was doing somthing simular... it was the IC pump as i suspected...
I thought all was good... it just happened again today? To me it felt as if the car was going into limp mode. The RPM's were not a factor.
Old Nov 2, 2007 | 12:56 AM
eckstiga's Avatar
CLS55 IWC, E55, S65
thanks guys will try to check the IC PUMP..will let u guys know..
Old Nov 2, 2007 | 01:01 AM
eckstiga's Avatar
CLS55 IWC, E55, S65
Originally Posted by TopGun32
3k? you sure?
yes..she wont go full load..it felt like the kompressor just shut down if over 3000rpm..well i live in jakarta, indonesia hence the bad traffic...hehhee
