K#N Part # for 04 E55? TIA
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Searched around, only to find out that there maybe different partnumbers for different years. ![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
K&N site says: 33-2181, but I read that this may not be the number that fits all models (2005 and up).
Any help is greatly appreciated.
Last edited by DirtyVegasMB; 11-25-2007 at 12:46 PM. Reason: Title correction for future searches.
Found this K&N part #: 33-2859
http://store.summitracing.com/partde...=1#Application
K&N site however does not show that filter available.
1 Post
10 Cayenne GTS, 07 Porsche 911 Turbo
2181's Will Fit
I had the same problem and went directly to K&N. After exchanging a lot of emails with K&N and their willingness to clearly demonstrate to me using an AMG airbox that the 2181 filter will fit I'm satisfied they do. I installed them and they work fine. I'm not sure if they make any performance difference though-
Ok... but yours is a 2005.
1 Post
I asked K&N the same question. According to K&N the airbox is the same size for all 2003-2006 E55's. K&N is in the process of eliminating filter part
numbers that overlap multiple cars. The 2181 filter is the same size as the previous 2586.
Really? Cause I read this from you and it had me worried:
I recently purchased a 2005 MB E55 AMG. Your website specifies a 33-2859 filter but, that has been recently discontinued. Instead you say the correct filter for an E55 with a 5.5L supercharged engine vs. the E/S500 with a 5.0L normally aspirated engine is now a 33-2181. YOU ARE WRONG! The 33-2181 is too tall and the filter housing will not seal correctly. Compare the dimensions of the two filters and you'll see there is a difference. Next time you think one generic filter size fits all do your homework! After many years of buying K&N filters for my BMW's, Porsche's, Shelbys and other high performance cars I'm switching to green filters and posting a copy of this email on all the websites I can.
