100 Octane is it worth it!
Old Nov 27, 2007 | 05:41 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
Can the ECU be changed by the dealership to accept a higher octane...If you have that type of relationship
Old Nov 27, 2007 | 05:46 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
I'm not sure the dealer can tune the ECU but I know Adam @ EvoTech can for sure
Old Nov 27, 2007 | 05:58 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Don't quote me on this, but I think they (stealer) can change you to 93 octane setting on ECU. Had a couple of guys try this with poor results so they went back to standard setting.
Old Nov 27, 2007 | 06:09 PM
JamE55's Avatar
Out Of Control!
Just go to one of the trusted tuners out there and do it right the first time. Going to the dealers sounds like you're cutting corners. Just my 2 cents.
Btw...VP MS109 FTMFW!!!
Old Nov 27, 2007 | 06:42 PM
Also just an FYI if the caravan goes through Tracy on the 8th and you are in need of 95 or 100 octane. On Tracy Blvd & Grant Line, the 76 on the corner sells the VP racing fuel.
Old Nov 27, 2007 | 06:57 PM
Jrocket's Avatar
E55
Unleaded?
Jakpro1's Avatar
Hey, if you just wanna run 100 for the event, just put it in and run the car for a hundred miles or so. Gotta let the ECU adapt and she should run fine.
No need for reprogramming etc. Heh heh, unless you want to......
Then call Adam!!!
Old Nov 27, 2007 | 07:22 PM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
Then call Adam!!!
