Valentine hardwired in upper console...
Old Dec 31, 2007 | 07:52 PM
I Like Soup's Avatar
2003 E55 AMG
Exclamation Valentine hardwired in upper console...
I just did it today and took a bunch of pictures. I know this topic has been around for a while, but figured I could try to contribute something and it doesn't seem like the upper console method got much attention. Anyway, if y'all are interested in pictures, I can figure out how to post them!
Old Dec 31, 2007 | 07:57 PM
MACHC5's Avatar
Veteran: Army
CLK63 Black, E350 Wagon, Supercharged Denali, Lotus Elise, Tesla Model 3 Dual-Motor.
I'd love to see how you made it work...
MachC5
Old Dec 31, 2007 | 08:28 PM
Roar's Avatar
07 SL55 P30 Designo - Sold, 06 E55 Wagon, 04 CLK55A - sold
Yes, please post your pics. I will be adding a K40 or V1 in the next couple of months in my e55 Wagon. Anyone done a hardwire in a wagon yet?
Old Jan 1, 2008 | 05:36 PM
BenzoManNY's Avatar
E63, SL 550 Sport,C63 Coupe On the Way!!
i still think the rear view mirror is the best option, i would like to see how yours is done.
Old Jan 1, 2008 | 05:55 PM
Ted Baldwin's Avatar
300ce
............talking about rear view mirror radar detectors. I have a complete Passport SR7 with ZR3 jammer that was installed in my car including integration into the rear view mirror. All the neccessary pices are here for stealth rear view mirror installation if anyone is interested. I removed from the car before selling it.
Ted
Old Jan 1, 2008 | 08:51 PM
Blacksport350's Avatar
Formula Mazda, Beast Junior...400HP 135i
I would be curious what you tapped for power as I am about to do this on my E55. I did this on my C32 and used the feed that powered the auto dimming mirror/garage door opener as it was switched power. It worked great!
Old Jan 1, 2008 | 09:12 PM
PerisanGodFatha's Avatar
is Sick as Fu*k
WOW Ive been waiting for somebody to hardwire it up like that show pics, and give an explanation....FINALLLLY pictures PLEAAAAASEEE AND EXPLAIN PLEASEEE
Old Jan 2, 2008 | 12:43 AM
2003 E55 AMG
OK, here ya go!
One point of note, we did try simply direct wiring the Valentine's power cable to the power source, but even showing 12v from power to the end of the power cord, when we plugged it in it didn't turn on. But, when you used the Valentine adapter, it did. I have no idea why it wouldn't since power was there, but maybe there is an inverter or some crazy Valentine specific something that enables it to only work with their own adapter...anyway, here goes...
Oh, and the names of the photos are kind of what we did so simply click on the picture to clarify...
1. Pull center piece down (it is the one that the rear view mirror stalk goes through),
2. Take front cover off (the one that covers the auto stuff that is facing the windshield),
3. On either side of the upper console are two black tabs, push them and pull first the front part, and then the rear part (as jdreef says, be careful of the ribbon cables!),
4. There are three black clips that hold the wiring down nice and neat (unclip them so you can have some good movement with the upper console to get where you need to),
5. Using tap in connectors (I used 14-18 gauge from Radio Shack since the bigger ones didn't work), tap in to the black/red (positive constant on 12v source) and brown (ground). I trimmed back the black tape wrap on the wires to give plenty of room since the connector is somewhat recessed in the console,
6. We did use the Valentine hardwire assembly and placed it in the upper left part of the console where there was plenty of dead space,
7. Clip everything back up, plug everything in and away you go!
Attached Thumbnails Valentine hardwired in upper console...-pull-center-piece-down.jpg   Valentine hardwired in upper console...-take-front-cover-off.jpg   Valentine hardwired in upper console...-reach-up-center-console-push-black-tabs.jpg   Valentine hardwired in upper console...-pull-front-down-then-back...view-right.jpg   Valentine hardwired in upper console...-unclip-three-black-clips-keep-bundles-tidy.jpg
Old Jan 2, 2008 | 12:51 AM
2003 E55 AMG
The last few photos...
Finishing up the tap in...
Attached Thumbnails Valentine hardwired in upper console...-now-you-ready....jpg   Valentine hardwired in upper console...-we-unplugged-everything-test-but-these-constant-wires-use.jpg   Valentine hardwired in upper console...-valentine-adapter-hardwire-pushed-up-corner.jpg   Valentine hardwired in upper console...-wires-tapped-constant-using-14-18-guage-tap-ins.jpg
Old Jan 2, 2008 | 12:56 AM
2003 E55 AMG
How it looks when completed...
A couple of photos from the inside, and outside. I must say, with my tinting, I couldn't see the Valentine display when I was standing outside my door so there is no way anyone would see it from behind.
I live in the Phoenix area so I drove around to the stoplights that have those annoying radar displays that show your speed (note: they don't go above 69mph!) and the detector worked fine from front, back, and side. I was a little worried when I drove down the freeway near a big shopping complex and it didn't go off when it normally did, but then again, I haven't been around there in a while
Hope this helps!
Attached Thumbnails Valentine hardwired in upper console...-view-car.jpg   Valentine hardwired in upper console...-view-passenger-side.jpg   Valentine hardwired in upper console...-very-closeup-view-front.jpg
Old Jan 2, 2008 | 05:40 AM
way2evil's Avatar
1989 Toyota Tercel Coupé
looks very good and clean. do you usually run it on that "L"? I usually use A. Not sure of the difference. What does everyone else use?
Old Jan 2, 2008 | 09:32 AM
2003 E55 AMG
I usually use the small "L" around town as it discerns some of the random crap out, I think. On the highway, I put it in "A".
Old Jan 2, 2008 | 09:46 AM
CyE55's Avatar
‘11 SLS, ‘19 GT63 s Edition One
Thanks for the pics and the precise instructions!
I was told that putting the unit up where you have put it cuts down on the range forward because of the tinting on the upper band of the windshield and cuts down on the rear range because of the way it's situated the rear antenna can't get a clear shot out of the back window.
But you say you got good signal driving around town eh?
Old Jan 2, 2008 | 11:53 AM
2003 E55 AMG
Well, take a look at the front view of the windshield picture and you can see the Valentine antennae has a nice view of the outside world. And that tinting is window tinting, not the Mercedes stuff. I picked up the radar display around town from behind for a very long distance.
Old Jan 2, 2008 | 01:54 PM
is Sick as Fu*k
Great write up, but it looks like to much for me to do w/o screwing somthing up...Anybody want to help?
Old Jan 2, 2008 | 07:19 PM
MACHC5's Avatar
Veteran: Army
It sounds like you wired it hot instead of with the ignition on...Why..?
Old Jan 2, 2008 | 07:33 PM
2003 E55 AMG
No switched voltage up there...I guess there may be in the rear view mirror, but I didn't want to take that apart. I have no problems simply turning the detector off if I'm not going to be coming back to the car for a while as I am usually adjusting the volume here and there anyway.
And...I didn't feel like running the power down to the fuse box or cigarette lighter because I figured the more real estate I have to run something, the better the chance of me breaking something!
Old Jan 2, 2008 | 07:39 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Valentine V1 Hardwired Installation And Pictures
Nice write up and pictures, thanks.....
Old Nov 18, 2009 | 12:01 AM
contentryder's Avatar
none
how did u take off the front cover?
Old Nov 18, 2009 | 10:55 AM
bigswin's Avatar
E63 AMG
I've got mine hard wired as well but ran a cable down to the light in the glove box. Turns on and off with the ignition.
Old Nov 18, 2009 | 12:23 PM
RacerX0911's Avatar
I drive on the big L at all times... And the reason why it only works with the adaptor plug in is because you are using a different phone wire than what valentine gave you.
My bmw was not hard at all and it turns off with the car!
Old Nov 18, 2009 | 02:55 PM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
Well done sir!
Old Nov 18, 2009 | 03:17 PM
Vader13's Avatar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
Very Cool. I just run the wires under the panels and have my remote box plugged into the lighter and the box is sticky taped on the lighter jack. Pretty hoopty, but easy to take out and throw in the C class..
Old Aug 1, 2011 | 04:50 PM
GregMB's Avatar
BTT - So that I can find this when I get home tonight.
Looks like getting a stealth V1 wiring installation will be easier than I originally thought.
-G
Old Aug 1, 2011 | 05:13 PM
timeToy's Avatar
'08 E63 Wagon
Switched +12v in the dome light:
https://mbworld.org/forums/4489717-post7.html
