DIY Quaife Install
Old 04-04-2015, 04:51 PM
  #51
buffyclk500's Avatar
clk500
Like
Old 04-04-2015, 05:21 PM
  #52
Super Moderator
MJ50's Avatar
bone stock E55 AMG
Originally Posted by BrianS
Reposting pics on another hosting site. The thread to too old for me to be able to edit the original post.
edited original post so pics show up...
snowman133 (10-30-2022)
Old 04-07-2015, 03:35 PM
  #53
TTR
TTR's Avatar
R129 SL500 & W140 S500
Great thread! Maybe sticky?
Old 05-06-2015, 11:00 AM
  #54
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
Forgot to unplug the SBC prior to installation...
I followed this procedure last night with the exception of forgetting to unplug the SBC prior to starting. After it was all buttoned up we started the car and it threw two P0500 codes (speed sensors), ESP Malfunction, and ABS Malfunction.
Can anyone advise how to clear these codes or what I might have done wrong to get these fault codes?
Old 05-06-2015, 01:31 PM
  #55
SPONSOR
PelicanParts.com's Avatar
Great detailed DIY!
-Luccia
Old 07-05-2015, 01:21 AM
  #56
winks911's Avatar
2006 C55 RENNtech
This is an amazing thread.
I followed this thread and did a quaife install with the info here...
Just an update or one very important piece of info missed.
The left and right c clips are different size DO NOT MIX THEM UP...
YOUR DIFF WILL WHINE ON DECELERATION ....
I learned the hard way.
Old 01-04-2016, 01:14 AM
  #57
55Jeff's Avatar
2006 cls 55 amg
Anyone know the torque for the bolts holding the new Quaife to the ring gear? They are not in my WIS Thanks
Old 02-12-2016, 08:09 PM
  #58
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
Anyone happen to have the part number for the tapered roller bearings that go on the differential?
Old 02-13-2016, 12:53 AM
  #59
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
For qdf7v ,210 mm rear in my sl55 bearings are 003 980 1202 don't know what yours are ,they might be same
Old 02-19-2016, 05:11 AM
  #60
WANTED!!'s Avatar
Good to know. Can anyone confirm the part number is the same or different for a quaife QDF9V1?
Old 02-19-2016, 07:56 AM
  #61
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Great Topic. Thanks guys!
Old 02-21-2016, 07:14 AM
  #62
WANTED!!'s Avatar
So about that part number, anyone?
Old 03-26-2016, 09:58 AM
  #63
WANTED!!'s Avatar
So since no one here was able to confirm or deny part numbers, it took a little effort on my part to source the proper bearings as my local Benz dealer nor my Benz part supplier were able to assist me. The latter realy surprised me as they are usually quite good at it.
The tapered roller bearings you will need on each end of the differential are not the same part number or size.
They are made by a company called Timken. The part number for an 05 e55 are NP120839 and NP335170. Your experience may differ, but I the only place I was able to get them from was 123Bearing.com out of France. I was unable to find a us supplier for their automotive bearings, but these guys did come through without breaking the bank.
Hope this helps somebody else.
DVC (03-26-2016)
Old 06-04-2016, 09:43 AM
  #64
screw991le's Avatar
2010 E63 AMG
Sorry to dig up and older thread.
Nice DIY Btw!!
How much time should I expect an indy shop to spend on this. This is my next project and don't want to get screwed.
Thanks guys!!
Old 06-06-2016, 03:50 PM
  #65
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
Nice DIY Btw!!
Thanks guys!!
quaife says they would charge 5-6 hours to install
Old 08-04-2016, 04:27 PM
  #66
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
I'm getting ready to do this install on my car and the side bearings have me confused. There doesn't appear to be any way to set the side bearing preload. In fact, with the snap-rings holding in the bearing races, it would appear that the preload is essentially zero, unless you use a case spreader while installing the snap-rings.
Do any of these units have shims from the factory? I just ordered a bunch of "thrust washers" from MB (pn 230-353-05-62 and others) but I don't see where they would go.
What gives?
Old 08-04-2016, 06:42 PM
  #67
cnterline's Avatar
Just follow the DIY and don't mix up the C clips , see if you can find a large snap ring tool pictured,
Old 08-05-2016, 07:42 AM
  #68
cnterline's Avatar
Disregard following DIY if your installing the wave track I believe there install is different
Old 11-01-2016, 07:20 PM
  #69
ghlainez's Avatar
06 E55 AMG
cnterline how different? I'm about to tackle this project wavetrac and 3.06 gears. but want to know how different it is if any, don't seem to different to me. can anyone else chime in please.
Old 11-02-2016, 02:31 PM
  #70
JoeJErnst's Avatar
As far as I can tell, the only difference is that the Wavetrac may have a slightly thicker ring gear flange which requires you to grind on the case a little so you can get it in. Both units are adjusted using the same snap rings on the bearings.
Old 02-05-2017, 01:51 AM
  #71
carguyshu's Avatar
where can you get the various thickness snap rings to adjust everything? My shop has mine apart and the unit is needing adjustment
Old 02-06-2017, 01:18 PM
  #72
ghlainez's Avatar
06 E55 AMG
I'm in the middle of tackling this project and would like to change all bearings since I'm in there. 306 gearing and Wavetrac. Does anyone know a US supplier and part #'s for all 3 bearings?
Old 02-06-2017, 01:57 PM
  #73
JoeJErnst's Avatar
The only place I've seen them is at a VW performance shop, of all places:
http://autotech.com/index.php/185wk-...84-4-22mm.html
You can also buy them from Mercedes, but you will need to find a precision grinder to grind them to the thickness you need. If you are lucky you may be able to hand-sand your old ones like I did here: https://mbworld.org/forums/w211-amg/...lsd-setup.html
Old 02-06-2017, 01:59 PM
  #74
JoeJErnst's Avatar
No, but I got new side bearings from 123bearing.com. They are in France, but I ordered via their website and the cost wasn't too bad and shipping time was reasonable too. The part numbers I ordered were: NP604623-NP335170-TIMKEN and NP957403-NP120839-TIMKEN (according to my invoice)
Old 02-07-2017, 05:05 PM
  #75
MBNRG's Avatar
I would try Wavetrac as suggested in the other thread you queried to see if they still have a C-Clip kit available, as I know installers have had these kits ready in the past.
If no love from Wavetrac, Tracy from OEDiscountParts.com can help.
I was going through similar motions with my own LSD upgrade for a C63 W204 and thought I would need an assortment of C-Clips just in case.
Below is a list of varying thickness C-Clips for an E-Class after cross referencing Diff Bearings which seem to be the same across many models (C63, C55, SL55, SL500, etc). I am told these C-Clips are only available in Germany, with a lead time of 1 week for US delivery.
Hope this helps.
The following 2 users liked this post by MBNRG:
JoeJErnst (02-07-2017), msgadget (02-09-2017)
Quick Reply: DIY Quaife Install
