DIY Quaife Install
Old Feb 15, 2017 | 11:15 PM
  #76
ghlainez's Avatar
Veteran: Army
06 E55 AMG
Joejernst do you happen to have the part # for the pinion bearing?
Old Feb 16, 2017 | 08:15 AM
  #77
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
No, sorry. I did not remove my pinion gear.
Old Feb 16, 2017 | 08:52 PM
  #78
ghlainez's Avatar
Veteran: Army
06 E55 AMG
Does anyone know the part# of the bearings that hold the pinion gear?
Old Apr 26, 2017 | 09:29 PM
  #79
brad65ford's Avatar
2020GLC63
looking at this thread make me wondering if there are shops we can send our units out to that will take the how center section and install the lsd and all new bearings while correctly shimming everything.
Old Apr 26, 2017 | 09:34 PM
  #80
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
you should be able to take it out & to just about any transmission shop. The rear is also used in certain SRT dodge cars so it's not like it's something super exotic that no one knows how to do.
Old Aug 21, 2017 | 10:28 PM
  #81
jumph4x's Avatar
W210 DRFT BNZ
Thank you for this write-up. Going to tackle some differential work in September.
Old Dec 2, 2017 | 02:59 AM
  #82
jumph4x's Avatar
W210 DRFT BNZ
Thanks again for the wonderful write-up. I'm following your steps but currently stuck after taking apart the left side of suspension. The axle doesn't have a problem sliding out of the differential itself but how do you get it out of the wheel bearing and suspension side of things?
I hammered on it thinking it's simply spline stuck but may have overdone it and now the axle bolt doesn't even go on, haha.
I have a 2003 with the early 215 housing. Cheers, mate!
Old Dec 2, 2017 | 03:24 AM
  #83
55Jeff's Avatar
2006 cls 55 amg
I used a 3 prong puller, take the rotor off , make sure the axle nut is off at the hub and use the hub and push the Axel in toward the rear diff looking at the wheel to break it loose
Old Dec 2, 2017 | 04:30 AM
  #84
jumph4x's Avatar
W210 DRFT BNZ
The 32mm, right? Definitely off.
Will try the puller method.
EDIT: Worked with the three prong puller but was quite sketch, the amount of force that required was frightening. Thanks again, team.
Old Dec 5, 2017 | 02:37 AM
  #85
55Jeff's Avatar
2006 cls 55 amg
Yes it works, did you use a impact that is best on them for the axle, hand cranking it will turn the puller
Old Dec 5, 2017 | 04:29 PM
  #86
jumph4x's Avatar
W210 DRFT BNZ
Correct. For anyone reading, that was the ticket. Autozone largest 3-prong puller + Dewalt DCF899P1 20V MAX XR and being very gentle on the trigger.
Old Dec 6, 2017 | 03:20 PM
  #87
bizzy247's Avatar
'06 R53
n00b question here: I ordered a front wheel bearing from FCP Euro since I suspect a bent wheel may have led to a prematurely worn wheel bearing. Would the same approach apply to the front wheel bearing?
Old Nov 12, 2019 | 12:35 PM
  #88
RKP Waco's Avatar
1999 E300
Axle MOD
Did you have to do anything to the axles? I just got something that the axles have to be modified to hold them in the differential. With the factory rearend there were c-clips holding them in, but with the Quaife there are no c-clips.
