*** VR700 for M113 Kompressor ***
Not to Mention it will Be Funny when My Little Kompressed SLV8 TT Dominates Every SLV12 TT!
Dont you this coulld be cause their transmission programmed to accept all the torgues is makes ???
May be with proper TCU which does not have torgue limiter 60fts would be better ???
The way I see it the only option is a looser torque converter, keep it a lockup-style like now but higher stall. Fuel economy in the city will suffer but it could also help to mask supercharger engagement, just thinking out load.
What I like about the v12's are those bad *** 60ft's on dr's and they definitely take less to initially mod but so do all turbo cars.
Chipped 65's are capable of 750lb-ft torque at the wheels and 10-second 1/4 mile times without nitrous. Without Nitrous, the highest torque 55 engine can make is around 550lb-ft... 200 less than 65 and low 11's in the 1/4 mile. There is a reason the world record for the fastest (225mph) 4-door car is a Brabus CLS with a V12 engine swap. If they could've achieved that record with 55 engine, I doubt they would go all out and swap the engine.
Barbus did the V12 Engine Swap because it's Easier to get More Power, but that Doesn't Mean One can't with a 55. Stay Tuned!
The reason Brabus decided to go that route because it was easier for them to do an engine swap than develop a larger blower or make it turbo.
Here I cant even think about it....cause I cant hook up...
Last I know, The Heads Were on Their Way to Canada to be Turned Into Stage III Heads.
The Enlarged Ferrea Valves Take 4-5 Weeks to Come In and it takes 1 Week to Complete the Stage III Heads.
I Just Have This Weird Feeling That My Heads Might Be Finished A little Faster Than I Thought.
On a Side Note, I Did Add a Small Addition to the List Of Mods.
I'll Let Victor or Vadim Comment On It Whenever They're Ready.
Stay Tuned!
Or
Custom AWD setup?
Or
'Strong like bull!' tranny?
That's Just Impossible!You Win Something For That One!
To Answer The Other Two: No and No.
It's HUGE!!
That's all I have right now... But since it's you, I'll give it one more try. So, from this Army brat -
'The Power Of Flight.'*
*'The Power Of Flight.' No longer available in Havoc's SL55....
