Vehicle Rising Malfunction
right now I'm having an issue with my lights.. one light is pointing higher than the other..
I have adjusted them.. but then after a few days.. the light is pointing too low.
I have 2 issues with my car..
my battery died a few weeks ago and its just barely has enough amps.. probably need a new one soon.
also I have a replacement tire on my drivers rear.. since one of PS2 tires was ripped.
The tire size is 275/40 and 275/35 18's.
I'm thinking..
suspension is adjusting for the larger tire
suspension does not reset due to low battery power ( my key less go is not working either)
or my lights don't level to low battery..
my plan of action is to, find a replacement tire, change the battery, take the dealer.
I'm thinking..
my thoughts exactly.
I'm thinking..
Did you replaced both rear tires and just the one? If you up the size on just one rear tire you will wind up your diff. That is also why one headlight would be lower than the other. That’s not what you did…… is it?
