Wheel locks for HREs
The wheel lock should be the same. It should also be the same length.
The reason you need to take this measurement is because different wheel manufacturers sometimes have different hub thicknesses, where, for example, a stock bolt may not extend far enough into the hub when used on an aftermarket wheel. If the wheel bolts are too short, the wheel could come loose, and if the bolts are too long, they will likely interfere with something inside the hub. There is some standardization, but safety reasons dictate you perform the simple verification of correct length.
Chances are, the Gorilla wheel bolt locks that will fit with the HREs are the ones that have a cone mounting surface and have a thread length of 1.05" (26mm), and are M14x1.5 as noted above.
You are so dead on and about the gorrilla as well.
