Best Oil Brand For High Performance Vehicles
Old Apr 10, 2008 | 03:25 PM
MRAMG1's Avatar
S600, GL450, GLC 43
Originally Posted by D Bst
Oh geeze....
Post #15 is from a guy named Steve Weiner - who is *VERY* respected in the Porsche comm. for his knowledge....
AARGGH
I'm not buying the part of them picking up a few HP
I think he is looking to sell some oil
See yeah
Old Apr 10, 2008 | 04:26 PM
I Like Soup's Avatar
2003 E55 AMG
Originally Posted by Jakpro1
I am telling ya guys, I saw the "Royal Purple Challenge" performed right in front of me. Katech Caddy ran 423rwhp on the dyno, then swapped out the oil to Royal Purple and actually lost 1 hp.
Not to sure if you should get so worked up about a .23% difference between runs there Jak.
With Mobile 1 admitting to changing their recipe, it probably wouldn't hurt to do more research and see what one finds.
Old Apr 11, 2008 | 07:52 PM
CWW's Avatar
CWW
SL600
Oh geeze....
Just when I though I had a handle on it, the game has changed....
http://forums.rennlist.com/rennforum...d.php?t=407224
Looks like he's now saying avoid ALL new Mobil 1 oils and moved to Brad-Penn...
AARGGH
Although I have to admit to finding a lot of entertainment in the fact that the dude is named "Weiner", his point is valid...
The newer Mobil1 products suck. And it is untrue that ALL oils have reduced phosphorus, only us-produced oils. You can still buy Penrite or whatever, with the phosphorus still in it.
Personally, I'd rather replace a cat every 70k miles and have an engine that could last 180k miles, than the other way around.
Old Apr 11, 2008 | 07:55 PM
CWW's Avatar
CWW
SL600
Similar thread over on Rennlist some time back in the 993 section (Porsche forum).
Yes all oils have had the phos. content reduced (IIRC it's now SM rated oil but was SL??).. anyway, the 993 crowd can be a little nuts about oil, as it's not just the lubricant, but also the cooling mechanism for our older engines.
So, the long and the short of it (and I'll post the link if I can find it) was that Mobil 1 was still good, but you *might* want to add a GM sourced cam and lifter lube (4oz bottle) with each oil change to bump the ZDDP level up a bit and assist the wear additivies.
Off to search for that thread now...
Honestly though... Oil selection is like women... one mans ugly is anothers beauty..
Sounds like a smart idea, but what product specifically, and where do you buy it? Autozone? I wanna pick some up and put it in...
Old Apr 12, 2008 | 07:58 AM
"G"'s Avatar
"G"
2005 e55 amg
Royal purple & amsoil are gay.
Run one of the following & you'll be all good.
Elf
Eneos
Mobil 1
Old Apr 12, 2008 | 10:13 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Ah, you night want to check on that info, if it is sold in the US, it has to meet our lovely goverment regulations. I do agree totaly with engine over the cat option. If mine ever clog, its straight pipe for me baby.
See yeah
And NO, Mobil 1 is still a great option out of ALL US made/sold oils my friend.
Old Apr 12, 2008 | 10:41 AM
  #32
Timeless's Avatar
2005 E55 ///AMG
Elf
Eneos
Mobil 1
Old Apr 12, 2008 | 11:10 AM
  #33
CWW's Avatar
CWW
SL600
See yeah
Wonder if you can just buy the original formulations online from canada? They still sell them everywhere else but here...
Old Apr 12, 2008 | 11:12 AM
  #34
CWW's Avatar
CWW
SL600
Also, anyone have anything else to say about adding cam & lifter lube to your crankcase, to compensate for the government-mandated phosphorus reduction, like someone suggested?
Is that a good idea? If so, what product to use?
Old Apr 12, 2008 | 01:53 PM
  #35
MRAMG1's Avatar
S600, GL450, GLC 43
Not thats a good idea
I am not sure about the change in formula date, but I will look into this for all of us.
See yeah my friend
Old Apr 12, 2008 | 02:16 PM
  #36
"G"'s Avatar
"G"
2005 e55 amg
http://www.lubricants.elf.com/lub/lu...5?OpenDocument
http://www.eneos.us/index.php
http://www.mobiloil.com/USA-English/...Oils/Oils.aspx
Old Apr 12, 2008 | 02:40 PM
  #37
sack5000's Avatar
2015 AMG C63 S
Thanks for the info, do you recommend one of these?
This thread is starting to suck. Granted Mobil 1 had to reduce the phos in the oil but nobody can say what effect that really has on wear and tear. Also, why would MB put 0w-40 in AMGs if 15w-50 is better per the table above?
Old Apr 12, 2008 | 06:29 PM
  #38
"G"'s Avatar
"G"
2005 e55 amg
I like them in that order, elf, eneos, mobil 1. I usually rotate between the 3 depending what i get a good deal on.
Old Apr 12, 2008 | 06:55 PM
  #39
Chargin55's Avatar
2003-E55 2011-C63 2016-C63S
I just had car serviced. They used elf. Average temp now 90. Used to be around 80. Don’t know oil used viscosity. Could change in viscosity translate to higher running temp???
Old Apr 12, 2008 | 08:14 PM
  #40
"G"'s Avatar
"G"
2005 e55 amg
I doubt it, how many miles did you wait till you did your oil change?
Old Apr 13, 2008 | 12:36 AM
  #41
D Bst's Avatar
2004 E55 AMG; 1995 Porsche 993 Cab.
GM Engine Oil Supplement (EOS). GM part # 88862586
Might be able to get it form your local GM dealer... but quite a few places online have it...here's a couple (no affil etc... just quick links).
http://www.gmpartsdirect.com/results.cfm?vc=1&wtype=v4
http://www.jegs.com/i/GM%20Performan...0002/-1?CT=999
And here's the refernce for it's use and why.....long read but worth it...
http://www.lnengineering.com/oil.html
Old Apr 13, 2008 | 01:29 AM
  #42
MarcusF's Avatar
2002 CLK430
ILSAC GF-4 is the specification that states phosphorus levels for the oil must be less than 800 ppm. ISLAC stands for International Lubricant Standardization and Approval Committee, and GF-4 is an industry standard, not a federal standard. Mobil1 0W-40 has a phosphorus level of 1000 PPM and therefore does not meet the GF-4 standard. 0W-40 is not scheduled to have any change made in the formulation. Mobil1 5W-40 is the product that was scheduled to be reformulated in early 2008. This is according to a Mobil1 doc that’s less than 6 months old.
Old Apr 13, 2008 | 06:10 AM
  #43
MB_Forever's Avatar
E63 P30, CL500 Sport
I just asked friends of mine who are living abroad, and they told me that the Mercedes dealerships are all recommending (and using) Mobile 15w-50 for all their AMGs and Maybachs. I wonder how reliable the 0w-40 is compared to 15w-50
Old Apr 13, 2008 | 07:18 AM
  #44
OzE55's Avatar
2003 E55
My last service record was 0-w40 Mobile 1 - Brisbane, Australia.(sub-tropical)
I would be concerned about using a 15-wXX anywhere it gets cold (near freezing). The high viscosity at low temperatures will mean increased wear at start up as the oil is thicker and less lubricious.
Old Apr 14, 2008 | 03:42 AM
  #45
MB_Forever's Avatar
Sorry, I actually meant 5w-50 not 15w-50...... he told me that they're using that for all Mercedes vehicles
Old Apr 14, 2008 | 07:02 AM
  #46
Chargin55's Avatar
Car was serviced right on schedule as per computer countdown. I believe ELF is a good brand. It is not that well known / popular in Australia however I have done some research since I became aware it was put in my car (as you do) and it is used in Renault F1 etc etc as well as most GP bike teams. My car says to only use Dunlop tires or Conti's and most posters have strayed from this recommendation. Still I just can't help but think......"oils aint oils"
Old Apr 14, 2008 | 07:45 AM
  #47
OzE55's Avatar
2003 E55
Did a MB dealer use Elf? If not why did you go for it? Just interested.
Old Apr 14, 2008 | 08:33 AM
  #48
Chargin55's Avatar
I have an 03 which is out of warranty. I take it to West Star Autos for service. guy there is ex service manager at Marshall Motors, which is one of Sydney’s biggest MB dealerships. He is a great guy who knows the product inside out. I did not tell him which oil to use but after research I am not fussed at all that I am on Elf. Where you at in Brissy. I’m on the Gold Coast next week. We should hook up.
Old Apr 14, 2008 | 11:06 AM
  #49
CWW's Avatar
CWW
SL600
I currently have whatever Mobil1 the dealer put in the car, and have around 3k miles on it since the last oil change. Is it ok to include the top-end/lifter oil in the crankcase now, or does it have to be done only with virgin oil?
I should note I am talking about an M120, which is a huge block...I am sure there is room to spare for the additional fluid level...so I mainly wondering if I will have issues with the lifter lube properly mixing in with the already run-in Mobil1...
Old Apr 14, 2008 | 12:12 PM
  #50
D Bst's Avatar
Let me say I'm not an oil expert....
But, I would assume that adding the "extra" supplement will do no harm...
