Primary Cats Deleted...now it rattles and rumbles
Now the car rattles. The whole car shakes when I decelerate.
I was think of adding flex joins/pipes on the straight pipe to try to get rid of the rattle, or maybe resonated test pipes?
Any other suggestions?
Thanks.
I know that the V8 rumbles more with exhaust modifications, but this was pretty bad. At 1500 to 2500 rpm, the exhaust rattles and shakes, and I can hear the vibration of the pipings. At higher RPMs, it goes away.
We checked it and there was no exhaust leak. Nothing was touching the heatshield either.
The secondary cats still have the cross-over.
Sounds great though.
I was think of adding a flex join on the straight pipe to try to get rid of the rattle.
Thanks.
Ted
I went under the car and inspected the whole exhaust again. I don't see anywhere contacting. However, I did noticed on one side of the welding the pipings are misaligned. There is abount half an inch step where the welds are. I'm not sure if that is what causes it to resonance. I'm going to have that part re-welded along with putting on the flex-pipes to see if I can fix this problem.
I'd go with faulty bracket / welds / fitting hitting body work somewhere. You say when you decelerate ... so look for forward and backward play.
