LED License, Door, Floor Lights
LED License lights
http://cgi.ebay.com/ebaymotors/ws/eB...239686489&rd=1
LED Door, glove compartment, trunk, dash, and seat LED Lights
http://cgi.ebay.com/ebaymotors/ws/eB...226652708&rd=1
Has anyone had success with LED's???
I just got my white plate bulbs from hoen-usa.com. they're not as birght or white as led's but whiter than stock and no error light nor flicker. They'll last longer than led's.
"LED bulbs have Positive and Negative poles. Only when their polarity is connected correctly, it will light up. If it does not light up, it does not mean the bulbs are defective, simply reverse it 180 degree and push in again."
I flipped the bulb on one side and tried again. Bamn! it worked with no error. I did the other side and they both lit up. Much brighter at night with no error.
Like some other members said, they burn out quick. I should take their word for it but we'll see over time how they hold up. If/when they burn out, i will update this thread.
How can I remove the overhead bulbs? It seems impossible to get under the cover without breaking it. Is it possible to change the overhead ambient lighting? The light orange is pretty repulsive.
Also LED license lights work nice too... so far....
+1
My license LEDs have worked for over two years,
If your car is blowing LEDs you may have an electrical problem the two most common causes of led failures are voltage spikes and AC voltage,
Voltage spikes are caused by a weak battery or defective voltage regulator. The AC voltages are bad diodes in the alternator. Both conditions can present no problems to other electrical systems in the car, and in fact the car can operate just fine.
Seems to trick the internal diagnostics computer into believing there is still a load across the bulb.
Used blue BTW and it looks cool.
