Frist Check Engine light with the AA ecu
Before you get pissd, GET THAT FILE and make sure you can go back to stock if you want to. If you lose that file, MB can't help.
ECU are needed but a pain in my opinion.
My car is at the dealer for another 2nd air pump relay failure. They will probably flash my car once more. Good thing I did not pull the trigger on the ECU Tune since I would had to return my ECU to a tuner or travel to my nearest Tuner.
Time and $$
I'm seriously considering taking off my ASP and running stock with just my HE, filters.
There is no secret that Code3 is working a smaller clutch pulley for our E55 which will create less boost that ASP and in par with other pullies in the market.
I rather have a small increase in HP and TQ across the rev band.. then having too much torque down low and loosing HP on top.
I have though of keeping my ASP with a smaller clutch pulley..(upper and lower pullies) but I will only imagine my need for Tuning will be multiplied and car will be running RICH all day long.
Time and $$
I would take the ASP off, if you have no tune. At the minimum, you need the TQ limiter cut off, just so you don't dump fuel at 2+ psi in boost over stock. Even the "standard" oversized pulleys hit the wall at the top end. The VRP one NEEDS the tune.
Now, I am a bit confused on the clutch pulley and how that will lower psi. I assume you mean they will tune the setup to mimic the standard oversized pulley conditions? Anyhow, I'd be very careful with messing with the SC clutch or the pulley on it. That just has not been tested much and you may or may not want to go there with your own car. I've got little room to talk, since I let VRP/Powerchip have their way with my car and anything can happen.
I would try to talk to a tech about the code you erased and find out how to fix it.
I'm thinking you don't have any warranty left... therefore avoid the dealer as much as possible.
If you have access to your OEM file, GET IT. Also, check with your dealer to see if your vin is "owed" a flash. if it is, then you are fine and can go in and start on a clean slate. If not, your original file is the ONLY way back.
Final option is to come copy my file!!!!
I'm not bashing, but want to explore this a bit more.
rflow: What year is your car?
Is it safe to assume you DID NOT have the dreaded air pump recall?
I am now curius to see which tune is more aggressive; the one that uses an older MB ECU flash (pre-air pump) or one that uses a "new" one. This may have something to do with all of the differences many of us feel in our cars and why I am getting raped for enjoying mine.
To me that just seems like a bit of a short-cut that may be asking for problems ...
Also the statement from Omar seems less than forthcoming if all they did to make the 'proper adjustments' for a recall flashed ECU was to use an older non-reflashed ECU from another car and load it on to yours.
