Steering Rack and Pump replacement
Old Jun 20, 2008 | 08:06 PM
Fr33kn63's Avatar
E63 AMG
Hey all. Anyone else have to get this replaced by the dealer? My Steering Rack and Pump are making noise. Was curious if anyone else has experienced this in the MB's. I am driving an E63 if you dont already know.
Old Jun 21, 2008 | 12:19 AM
jangy's Avatar
2015 S212
That is new, but what kind of noises? We have some members with odd noises under there that may be the same.
Old Jun 21, 2008 | 08:01 AM
Fr33kn63's Avatar
E63 AMG
First noise I am experiencing is when the car is fairly cold, when I turn the steering wheel left and right without moving the car I hear a popping sound like metal stressing like a creaking sound. coming from the front wheels.
Second sound is a little tougher. Doesnt actually start until you get above about 25 mph. You can also only hear it while driving alone barriers or walls or large buildings when you car hear your cars sound reflecting. I thought it sounded like a faint break squeal or metal spinning squeak. Its very faint, but you should be able to consistently produce the sound. Stealership claims its the coming from the same steering area.
The technician says that both sounds are coming from the front steering rack and pump as it is starting to fail. Mine are scheduled to be replaced monday afternoon into tuesday. SHould get it back then.
With our expensive cars we all need to be vigilant about dealing with the stealerships to fix these problems while they are uder warranty. If I wasnt so **** about my ride and had been some sorry schlub I might not have noticed or cared too much about the noises it is making.
Point is if you car is making odd noises, make sure you can repeat the sounds with the SA or demand a tehnician ride along with you so you can reproduce what its doing.
My ride is gong to hit 20k today(only like 20 miles off) The first sound had been there since the car was a few months old. Just couldnt consistanly reproduce it.
The second noise I only really noticed since it is a very faint sound in the last couple thousand miles.
Old Jun 21, 2008 | 11:51 AM
benzmodz's Avatar
W203 slightly modified
Since they dont replace the rack parts themselves it is just a policy to change the whole thing. The pump is just a precaution.
Old Jun 21, 2008 | 12:40 PM
Fr33kn63's Avatar
E63 AMG
Thats kinda what I was figuring.
Old Jun 25, 2008 | 08:34 PM
Fr33kn63's Avatar
E63 AMG
Well got my car back. Everything seems to be ok for the most part now. Not 100% happy but at least mostly.
Anyway thought I would mention a couple other things that came up on my car incase anyone else with an e63 is listening. Tech also replace while he was peeking around....
Replaced Idler Pulley -pulley bearings were worn
They also replaced the Rack mount Plate.
Brake fluid reservoir was leaking...replaced cap and covering.
it also turn out my coolant thermostat was leaking too-replaced thermostat
So those are the additional items they found. If you have an e63 you should look under the hood to see if you have similar problems.
Old Jun 25, 2008 | 08:41 PM
sick430's Avatar
CLK Cabrio
wow you should email the guy that built you engine ad inform him that he has forgotten a few nuts and bolts.
Old Sep 18, 2008 | 09:30 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
if i complain about the steering rack, would dealer replace it with 05+ steering rack under warranty?
Old Sep 18, 2008 | 09:58 PM
TheGreatOne45's Avatar
2018 GLC 300 4Matic
well i dont have an amg (yes i troll this forum) but i just had my car in for service on monday because i experienced the same problems and they replaced the pump under warranty.
Old Sep 18, 2008 | 11:40 PM
dbarrym's Avatar
'04 E55; '03 E500 Sport
Not on my E55, but my '03 E500 had the PS pump and rack replaced two years ago. It was making a 'grumbling' or rumbling kind of noise initially, and completely failed 300 miles later (it was on an XC trip over the Thanksgiving holiday, driving to Denver from Chicago, or I would have stopped immediately). Happened at 80K miles.
I would assume that the E55 pump would be similar in nature. Replace it quick, as the pump is pricey enough ($800) but the rack is even more so ($2K or so, plus labor)...if the pump impellers let go, the metal bits will quickly destroy the rack.
Old Sep 19, 2008 | 01:03 AM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Not unless the parts are superseded ..Then You Will get the Updated parts
Old Sep 19, 2008 | 12:06 PM
psk145's Avatar
2006 E55
my car makes a clunk when Im at a light (on the brakes), and I move my wheel to the left. I wonder if mine needs some sort of fix.
Its pretty repeatable, move left..clunk, let go, move left..clunk.
Old Jan 27, 2015 | 04:08 PM
bzliteyear's Avatar
07 E63 06 CLK55 Cab 03 P-car C4S
I know this is old thread, but has anyone else found other solutions besides spending $2k for parts plus labor?
PL
Old Jan 27, 2015 | 05:05 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
2 options
1. dont lower the car excessively it will damage the rack eventually
2. you can get a used steering rack
