FS - Methanol Injection Kit with Controller $200
Much safer than Nitrous but similar super-kick when you need it. Using just water in this kit will dramatically cool down your engine when weather surpasses triple digits this summer but if you add some Methonal which is MUCH cheaper than 110 octane gas, you are adding 118 octane boost in a flash! Be one of the few to blow your fello E55 modders away with this unfair but safe advantage for the cost of a nice dinner with the family. No need to lug a big tank around in your trunk that only lasts for a few shots and certainly not as dangerous or such an intrusive install. This kit installs in 1/2 hour or less.
Here's a few links describing the benefits of alcohol/methal injection kits.
http://www.snowperformance.net/, http://www.alcohol-injection.com/, http://www.alkycontrol.com/ or http://www.alcoholinjectionsystems.c...icle_info.html, http://www.aquamist.co.uk/ and finally http://en.wikipedia.org/wiki/Water_injection_(engines)
The only reason I removed it was because the HE was in the way of the resevoir and there was no other place to put the tank in a cramped C55 engine bay that already has a Kleemann SC and a bunch of other mods.
I never did a before and after dyno with the Kleemann since Vadim never isolated the difference due to this specific mod as he piled on 1 mod after another. He has to make an appointment to get the dyno done at this partner's shop so he's too busy to dyno it after every single mod at VRP.
Vadim, If you are in the house please chime in to validate my claim.
You are gonna LOVE this. Instant Octane, Condensed Cold Air and detonation prevention!
Please post your feedback on this forum but make sure you have it installed by a knowledgeable shop. It's not a DIY job for a novice but for a gearhead, no problem.
Why waste money on high octane gas when meth is so much cheaper and has much more octane 118-125. One tank lasts as long as 3 months if take it easy and 2-3 weeks if you mash it all the time.
btw...My car was tuned with Sonoco 110 by Jessie for both before and after dynos. EVERYBODY knows how AGGRESSIVE Jessie's tunes are...POS HPS was holding peak HP back.
edit: Never mind. I think you meant OEM 55k motor... but I'll be glad to run any E55 in So Cal as long as Vadim hasn't modded them with his VRP700 and above power packages. j/k
At least not until the entire engine gets bored out after my two weak cylinders give in.
i'll run you anytime.......you come out to phoenix.
btw, you list everything in your sig except any timeslips...how does she run?
Time slips and videos are coming. When temps dip below 100F I will be the first at Willow Springs this summer.
Just an FYI- A car tuned for meth that has a failed meth pump equals very bad news. And if you dont have safeties in place and you run out of meth/H2O its bad news too. If you dont tune for it, all it does is raise octane and reduce IAT's. I'm installing two meth kits on two of my friends RS6's.
re: MEO2...I always check the tank (visable behind front grill) before I leave the driveway. It's good advice for Albert (the new owner). I also listen for the pump when I hit it and I can hear usually hear it.
I should get my car back from Vadim this week and post new dyno numbers after latest mods. Then off to the track for videos of runs soon to be posted as well. I think I've pushed this little C55 as far as it can go without major engine overhaul. Not sure about Quad-Turbo, twin-charge, bigger capacity engine anymore. Wifey is getting a bit po'd and I understand why.
