1/8 mile times
03' E55
1/8 mile times
Want to hear what you guys are running in near stock or modified form
I made 2 runs tonight:
Mods:
2003 E55 42k miles
K&N filters
SL55 Snorkel Mod w/ cut off air inlet wings
20" DUB wheels with Nitto 555 tires
Run:1 Ambient temp 88deg
Hot off the street no cool down
60' 2.066
330' 5.675
660' 8.617
85.859MPH
Run 2 Ambient temp 80 deg
Major cool down; I had 32lb of ice on the S/C and intercoolers for nearly two hours. It was still a littlle warm to the touch in a couple place when I removed the ice bag though. Also tried sneaky ECU reset right before the run.
60' 2.037
330' 5.446
660' 8.232![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
88.037 Mph
car felt really good and seemed to shift quiite a bit higher. Shifter left in S mode and ESP off for both runs.
So how does this stack up against other near stock E55s?
Mods:
2003 E55 42k miles
K&N filters
60' 2.066
330' 5.675
660' 8.617
85.859MPH
60' 2.037
330' 5.446
660' 8.232
88.037 Mph
My personal best is as follows (stock):
60' - 1.795
330' - 5.107
1/8 - 7.827 @ 90.32
1/4 - 12.137 @ 114.83
Temp was under 60 degrees. The higher temps do make a difference and rob several tenths.
Your 60' times are not good. Knock off 3/10th's and do the math. Good luck.
T
60' - 1.795
330' - 5.107
1/8 - 7.827 @ 90.32
T
Mods:
2003 E55 42k miles
K&N filters
60' 2.066
330' 5.675
660' 8.617
85.859MPH
60' 2.037
330' 5.446
88.037 Mph
Mods:
2003 E55 42k miles
K&N filters
60' 2.066
330' 5.675
660' 8.617
85.859MPH
60' 2.037
330' 5.446
660' 8.232
88.037 Mph
03' E55
Air temps made a huge difference no doubt. And the 60's do suck. Not much I can do on these tires. I probably won't run again for a few months till the temps go down.
run number 2 is impressive power for the temps. Better 60 gets you sub 8. The 20" rims need to go buh bye although they do provide a wider stance and contact patch. They slow your trap 4 sure. Thanks for posting , it takes courage to posty #s of runs in higher temps but you have added to the fact base that cooling the SC and intake leads to making more power
'05 C55(sold)'05 E55(sold)'06 911C4S(sold)'06 ML350 '06 CLS55(sold),buncha slo bikes
old daily driver '07 E63(gone); new dd '14 750xi; 2013 Viper GTS
