Yesterday I installed a new (US spec) CLS63 instrument cluster into a 2005 E55...the only reasons to do so, were/are because of the fonds that are nicer then the original ones and the extra screens with engine oil temperature, battery voltage and laptimer.
Anyways - the cluster was new which made locking it into the EIS easy and the endresult is a new IC with old mileage and improved looks.
As we have a couple more of these new ICs in stock, we will be offering these clusters for the 209 CLK, 211 E-class and 219CLS (as long as stock lasts) for 750USD excluding installation/programming (for which the costs vary per model from 100USD to 200USD).
some pictures to show what is meant/what was done:
greetingz,
greetingz,
Wow, very nice!
I assume when you say W211, you mean all years? Is it possible to retain/retrofit the silver trim for install?
Of course, we've got to get you to Florida for it to really matter.
greetingz,
Nice. Would that go in to an '03 E55?Originally Posted by MBenzNL
Yesterday I installed a new (US spec) CLS63 instrument cluster into a 2005 E55...the only reasons to do so, were/are because of the fonds that are nicer then the original ones and the extra screens with engine oil temperature, battery voltage and laptimer.Anyways - the cluster was new which made locking it into the EIS easy and the endresult is a new IC with old mileage and improved looks.
greetingz,
Will the e55's that have this redline at 7k + rpms instead of 6400?
how could we get this if we lived in say...chicago??
Quote:
Mine does...
I love the new screens and think the gear display up at the top is awesome but much prefer the aluminum surround and the white dials. Hmmm, I wonder if it would be possible to take the new cluster and swap the dials and bezel with some not so minor surgery?!
Quote:
The ECU controls the ignition cutoff, not the cluster so the answer is that it will be the same as it was before. So if you have an ECU flash, it will rev out higher.Originally Posted by Mr. AMG 20
I see that the AMG peeps don't check the non AMG section as I posted a similar post about a CLS63 IC in a 2003 E500 one day earlier in the 211 section...
anyways: the CLS63 IC fits and works in any W211 BUT there is offcourse the difference in the RPM gauge (which doesn't really affect the car other then that you might not be able to reach redline anymore in cars that don't do that many rpm's (diesels for example)...ruining 2 clusters by trying to change th eblack dials into white dials is something you should NOT attempt...it would be easier to connect the CLS mainboard (4 connectors) to the E55 cluster and get it programmed (as it will function of the mainboard and that is new and unprogrammed).
The CLS cluster housing itself is black and doesn't fit the 211 (or 209) so in order to fit these CLS clusters in the 211 one will have to re-use the existing IC housing from the 211 cluster (either with aluminum or black faceplate).
greetingz,
greetingz,
Yes, it possible to have the same Silver trim which makes the cluster 2-Tone.
Please look at the picture on the link below or go to W211 section.
https://mbworld.org/forums/attachmen...1&d=1218220627
Moe
Moe
Moe
damn that looks good --2tonesOriginally Posted by Strictly4AMG
Yes, it possible to have the same Silver trim which makes the cluster 2-Tone. Please look at the picture on the link below or go to W211 section.
Moe
Quote:
The E63 has a shift light.Originally Posted by caymeatra
is there a cluster with a shift light?
that looks pretty good.
i wouldnt mind getting that done, especially if the shift light works!
please try it out and let us know!
MBenzNL are u coming to the vancouver, BC area anytime soon?
would u happen to have some sort of list of other options i could add to a CLS55?
(power folding mirrors, rear heated seats)
i think that the center screen in your instrument cluster will flash and tell you to shift. (something like that)
im assuming u have to select the right screen to do so.
maybe a 63 guy can chime in.
jikjak - Wanda from MBenzNL mentioned they would be in Vancouver sometime this year. We should get a few more locals to get stuff done! I'm thinking PF mirrors...Originally Posted by jikjak
that looks pretty good.i wouldnt mind getting that done, especially if the shift light works!
I love the updated look. $750 for the 63 piece and from $100-200 for installation?
MJ50
Super Moderator
close
- Join DateJul 2003
- LocationMBworld
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drivebone stock E55 AMG
Liked:969 Times in 940 Posts
Quote:
send email to MBenzNL@gmail.com for a quoteOriginally Posted by E55AMGGG04
I love the updated look. If you don't mind me asking how much does something like this cost with the cluster and install?
The entire center display will turn red when you approach redline and it will say, "UPSHIFT"Originally Posted by jikjak
i think that the center screen in your instrument cluster will flash and tell you to shift. (something like that)im assuming u have to select the right screen to do so.
Quote:
What he said^, I usually don't use this because I see the red look down and miss the shift. Its easier for me to listen to the motor and shift before redline.Originally Posted by LZH
I never look at it directly.....but see it out of the corner of my eye. It's really only usefull on the 63 in 1st and 2nd gear as they wind up really fast.
Quote:
With the 10 degree weather in NY right now 1st and 2nd gear just spin, along with alot of 3rd gear. I really try not to use up the rubber in this weather the stock tires really do now work well in this cold.Originally Posted by LZH
