What PSI for tires
I used to run Pirelli P7's 285f/345r tires on my RSR and 930's, and lowering the psi below 38 or so would wear out the center of the tread prematurely.
Of course this was mid-80's tire technology, sidewalls are (I'm sure) much stiffer now.
So, plz tell me what Nitrogen's psi that should be equal Air psi at 36f / 36r ??
Nitrogen simply DOES NOT expand as quickly as air, so there is some SMALL benefit. It will make NO difference on the street, except to cost you more my friends.
See yeah
PS: Please don't try the Hydrogen, it was for comic releif only guys.
Curious - where did you get your factory settings from? I could swear that my door and the sticker behind the gas cap cover tell me to keep it at 35 all around with just me in the car.
35 psi is fine for daily use, you are correct re gas filler door sticker. To each his own.
Nitrogen is simply not necessary for the street. The ONLY advantage I can see is that nitrogen fills have NO water.
If it was normal air at 21% oxygen and 78% nitrogen with no water vapor it would behave identically.
Water can change states and result in a larger tire pressure change with temp.
PV=nRT does not change much at all.
http://www.chalkbored.com/lessons/ch...aw-handout.pdf
Edit: Yea, I was right.
http://www.cartalk.com/content/colum...tember/05.html
