Update: MHP ECU/TCU Tuning (Throttle Blipping, etc, DONE!)
Just think of all the fun that will be had on this board after MIR.
as far as your pointless question is concerned, there plenty that trap what rock typically traps although none have matched his personal best yet (perhaps only because they haven't run under ideal conditions). however impromptu freeway runs don't mean too much because of so many variables so if you think there's any comparison between rocks pr of 124mph and andy's c63 at 117mph you really need to get off the koolaid.
Tom
With regards to the NOS, I would check your jetting MB cars run very high fuel pressure and throws off the jetting, just a suggestion. As far as how much you pick-up out the back that all dependes on how much rwhp the shot is giving you.
What bottle pressure do you run ?
Have you dynod the car with the nos ? The ecu could be dumping to much fuel negating some of the gains even though the shot you are using is very small and is probably closer to 75 hp at the flywheel. To pick up 8-10 mph out the back you would need closer to 100+ rwhp on the nos.
Have you thought about switching to a wet kit?
there's no reason you can't compare 55's to 63's but there's no way you can compare andy's 117mph trap to rocks 124mph unless andy's car does wheel stands and knocks out 1.4-1.5 60ft times. since that isn't the case it's quite safe to say those cars aren't in the same league on the drag strip. now if rock's car wasn't running as perfect as it was the night of his p/r then that can bring the cars closer for discussion. but in my book you still can't even compare a 117 to a 122.
Conditions are obviously of paramount importance. Hopefully we are going to have some great conditions at MIR in November. That will level the playing field for those of us who are forced to run at elevations from 650-1000 above sea level and in very high humidity. We will finally be able to put some of the specualtion aside. People have corrected some of my passes to 11.0's. I believe Andy's corrected out to an 11.7, which is pretty impressive for an other than ECU bone stock C63. I believe my 11.47 motor only pass corrected out to and 11.26 would it have been run at MIR, which, if I am not mistaken would shatter the quickest motor only pass on record made by any 55. I don't put too much faith in corrected numbers, I think a time slip with hard numbers are the only numbers that should matter. MIR should be very interesting and answer a lot of questions that have arisen over the past few months.
I'll tell you what the difference is so you can stop speculating. It's called TQ and the fact that 90% of a drag race is determined in the first 60'. 63s will never holeshot like 55s unless we throw a PD blower on top. From a roll, it's different story especially since the 7A keeps us in the band better/longer than your 5As.
Although this is true, you mis understood what I meant. I dont put faith in the correction data, there are too many variables. Its great for conversation, but in my opinion thats about it. No correction factor can accurately predict how my car will run under said conditions. Contrary to popular belief we east coast guys do run at positive DA 90% of the year.
Although this is true, you mis understood what I meant. I dont put faith in the correction data, there are too many variables. Its great for conversation, but in my opinion thats about it. No correction factor can accurately predict how my car will run under said conditions. Contrary to popular belief we east coast guys do run at positive DA 90% of the year.This isn't directed toward you specifically (so don't take it that way) but it cracks me up when people talk about corrected numbers like they don't mean anything. When you go to a dyno, what do you put more faith in, corrected or uncorrected numbers? Anytime someone posts a dyno sheet that's uncorrected they immediately get called out for the most legit CF (SAE, Smoothing at 5).
Now explain to me why correcting a timeslip is any different. DA plays such a HUGE role in how any car will run on any given day, it seems absurd to me to not correct for it. Yes there are many variables, but they are taken into consideration (humidity, DA, temp, track elevation, etc. are all factored in).
It seems like those that are most resistant to using corrected #s are those that run at sea level tracks (that can experience neg DA unlike the rest of the country) or those that are seriously old school.
Now take a car that runs 12.0 at MIR/Cecil/ATCO/NED and run it at Bandimere. You'd be lucky to run 12.80 or better. So if said car never runs on the East Coast, is it really a 12.80 car?
Finally it seems like a lot of people are also under the impression that corrected ETs/Traps are always quicker/faster than actual numbers. Well, as we'll see after 11/15, that's not always the case. I guess the real question post 11/15 is, will you claim the negative DA # or the corrected number?
Is correcting track data the end all be all answer? No, however, it's the most accurate method we have, just like correcting dyno #s is.
Jay, if you post the date/time/track and numbers (to the hundredth place) for ET/Traps on your record runs I'll be glad to correct them for you to see what you get.
Our 60s suck by comparison, meaning we aren't putting anywhere near the power to the ground that you are during launch (which I think we both agree is the most important aspect of any race?) which is where the trap discrepancy comes into play. After first gear, we don't have an issue since we never fall out of our powerband.
I can guarantee that corrected ETs/traps will be slower than uncorrected on 11/15. I'll still post both either way.
