Update: MHP ECU/TCU Tuning (Throttle Blipping, etc, DONE!)
Old Oct 7, 2008 | 01:28 PM
  #1026
MHP's Avatar
MHP
'09 C63 AMG
Originally Posted by jrcart
But your TCU tune is going to fix that little problem, hopefully it's going to let me spray out of the hole with a 3000 rpm launch
LOL, yes, nitrous does help in that respect.
Running out to the shop for few hours...
Old Oct 7, 2008 | 01:31 PM
  #1027
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Originally Posted by MHP
I guess you missed the part about the launch being important...
Our 60s suck by comparison, meaning we aren't putting anywhere near the power to the ground that you are during launch (which I think we both agree is the most important aspect of any race?) which is where the trap discrepancy comes into play. After first gear, we don't have an issue since we never fall out of our powerband.
no, i didn't miss anything, but you're totally ignoring my point. i KNOW your 60ft times are typically going to be worse than the 55's........which AGAIN is why you would have to trap a higher speed to put down the same et.
are we on the same page yet???
Old Oct 7, 2008 | 01:40 PM
  #1028
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
I still feel there is more behind the MPH issue than 60' times. Look at Juciees 1.69 60ft compared to his trap speed, it don't get much better than a 1.69 60footer does it? Now compare the trap speed of a 55 with a 1.69 60'. Still a 4-5 mph discrepancy.
Old Oct 7, 2008 | 01:41 PM
  #1029
JAYCL600's Avatar
new balance
Yes, but you're still at sea level.
no MIR is @ 80 ASL
DA plays such a HUGE role in how any car will run on any given day, it seems absurd to me to not correct for it. Yes there are many variables, but they are taken into consideration (humidity, DA, temp, track elevation, etc. are all factored in).
I agree with this. The issue arises when people use the programs that get weather data from the nearest NOAA station or airport. This data can horribly skew the data as the weather can be totally different at the actual track site. Unless you are using a professional handheld weather station, i dont put too much faith in the numbers produced "on the net" Just because one car reacts one way under certain weather conditions doesnt mean my car will react the same. I can only speak for my own car, I know how it will react under certain conditions as Ive compiled enough data to do so, and i wont use a computer to guess how someone elses will.
Jay, if you post the date/time/track and numbers (to the hundredth place) for ET/Traps on your record runs I'll be glad to correct them for you to see what you get.
this has been done, but if you want it for your own knowledge, everything you need is on dragtimes.
Old Oct 7, 2008 | 01:57 PM
  #1030
MarkoCL65's Avatar
CL65
Originally Posted by JAYCL600
I am blessed with East coast tracks because this is where I live. Although this is true, you mis understood what I meant. I dont put faith in the correction data, there are too many variables. Its great for conversation, but in my opinion thats about it. No correction factor can accurately predict how my car will run under said conditions.
Case in point. When you have a forced induction car that has the ability to cool the charged air to a temperature significantly below ambient or the ability to produce more boost, the correction formula is inaccurate. I have raced competitively with a turbocharged car with nitrous. That set-up has the ability to inject similar amounts of oxygen into the motor in greatly varying conditions. It ran within a tenth at Bandimere and Atco. The correction formula is most accurate when applied it to NA applications.
Old Oct 7, 2008 | 02:39 PM
  #1031
chiromikey's Avatar
you're right, there is likely more behind it. i can't comment on josh's 1.69 except that i think it was a fluke. i'm not sure he's been close since but i'm totally speculating as we haven't talked in a while. regardless, i don't think any stock 55's are putting down much diff mph than he is. the few other 55's that have run in the 1.6's for 60ft times are not stock so obviously their mph is going to be higher.
Old Oct 7, 2008 | 02:49 PM
  #1032
MHP's Avatar
MHP
'09 C63 AMG
I get what you're saying but overcoming the deficit at launch is a bigger factor than you're letting on. Any kind of bog whatsoever absolutely murders trap speed. We're out of the band for a significant amount of time in first gear, and it kills us.
Old Oct 7, 2008 | 02:53 PM
  #1033
MHP's Avatar
MHP
'09 C63 AMG
no MIR is @ 80 ASL
LOL, come on. That's still 770' better than Norwalk. Not to mention the difference in air quality. It's unusual for us to see under 2000-2500' until October.
Most tracks have weather stations on site and the NHRA correction website www.smokemup.com derives their numbers from said stations. I agree that a portable weather meter is probably the most accurate method, but we don't always have the luxury of using one.
That being said again I don't see how anyone can say corrected numbers are less accurate than actual ones. Anytime you eliminate variables you end up with a more accurate system of measure.
Cool, I had no idea. Just throwing it out there.
Old Oct 7, 2008 | 02:54 PM
  #1034
MHP's Avatar
MHP
'09 C63 AMG
Yes FI/nitrous (DA in a bottle) apps are a bit of a different story compared to N/A, that's absolutely true. That's why I never DA correct for nitrous.
Old Oct 7, 2008 | 02:56 PM
  #1035
MHP's Avatar
MHP
'09 C63 AMG
At this point I'd like to pat everyone on the back as I think we've gone an entire page without anyone personally insulting anyone else. If we could keep the discussion this focused all the time I'm sure we'd all benefit.
Old Oct 7, 2008 | 03:07 PM
  #1036
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
Come on Andy...think about it. Corrected #'s can have the best of both worlds... a warm track surface for a better launch ...and the ability to mitigate the weather by using a mathematical formula. Did you ever think that there is a point where the cool weather can work against you with the traction surface. It is all speculation until the car actually performs in those conditions. As Marko mentioned, the correction #'s are more accurate for N/A car.
If you are looking for precision...the actual numbers are more accurate...that is why in scientific research they test their theories by actual tests. No matter how good the mathematical models are they need to verify their theory. Yet correction factors are a decent indicator of the potential for a car to run at in certain conditions....but it needs to be tested for that particular model to see if it reacts as expected....or not....
Tom
Old Oct 7, 2008 | 03:25 PM
  #1037
MHP's Avatar
MHP
'09 C63 AMG
Tom, you do realize that vht works better in the cold (down to 40F) than on a hot surface. I also agreed with Marko reg. N/A v FI, and especially nitrous apps however the fact remains that corrected #s are still the most accurate and precise data obtainable from a track. Again as I said above, they aren't the end all be all, but the data taken at MIR in negative 1500' DA air is even farther from that.
Tom
Scientists test their theories in controlled environments Tom, you know that. Controlled environments equate to those with the least amount of variables...And around we go again. Not trying to be a dick but do some reading on what weather correction entails for ETs/Traps and also about why correcting for dyno #s is industry standard.
Old Oct 7, 2008 | 03:37 PM
  #1038
blackbenzz's Avatar
haters crazy
My 55 has run an 11.48 @ only 120.5mph
In a -4847585375 DA my car should go 9's, does that make it a 9sec car?
And stop talking about scientists like you guys know what they do. It is impossible to have a true "controlled environment" considering many variables are unkown and noone knows the effects of all the variables!
Old Oct 7, 2008 | 03:38 PM
  #1039
MHP's Avatar
MHP
'09 C63 AMG
Thanks for the useful contribution Ahmad. I believe that's why all runs are corrected to sea level
Old Oct 7, 2008 | 03:43 PM
  #1040
MarkoCL65's Avatar
CL65
It would be so fast that you'd wormhole into another universe right after the 60'.
Old Oct 7, 2008 | 03:50 PM
  #1041
blackbenzz's Avatar
haters crazy
I think it would just break lol
No prob Andy, thats what I'm here for. Useless banter... and to whoop some *** at the track!
Old Oct 7, 2008 | 04:03 PM
  #1042
MHP's Avatar
MHP
'09 C63 AMG
When the flag drops the bull**** stops.
Old Oct 7, 2008 | 04:04 PM
  #1043
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
it's too bad andy seems to be of the belief that any attention is good attention. if he had any sense, he'd put your muzzle back on. just because you're used to having his sack in your mouth doesn't give you the right to put words in everyone else's. i never said you have anything to gain by your ignorance. and your quasi credentials don't impress me and don't make your cheer leading any less miserable to witness.
as far as your pointless question is concerned, there plenty that trap what rock typically traps although none have matched his personal best yet (perhaps only because they haven't run under ideal conditions). however impromptu freeway runs don't mean too much because of so many variables so if you think there's any comparison between rocks pr of 124mph and andy's c63 at 117mph you really need to get off the koolaid.
Yikes - you seem to be a very angry little man, Mikey. And as far as my "pointless" question....well, remember you are the one that stated that Rocks car was only "moderately" modified and I think we can all agree that is not the case at all.
Old Oct 7, 2008 | 04:09 PM
  #1044
MHP's Avatar
MHP
'09 C63 AMG
Are you saying that scientists don't try to eliminate as many variables as possible when conducting an experiment? Sorry bro, I had O-chem in college (random other bio/chem classes to boot) and that was my personal experience.
Old Oct 7, 2008 | 04:13 PM
  #1045
TMC M5's Avatar
All cars will not react the same. I would be in agreement with you if you ran a particular car hundreds of times in varying conditions and document temp, air pressure, humidity,..etc. I would say that you may have enough data to create a mathemetical model to derive accurate correction factors. That model would be a pretty accurate depiction of how your car will react in certain weather/air. You could then test it to see if it actually works. Taking some sort of correction factor that was developed to give an illustration for all sorts of different cars (turbo/ supercharged/fuel injection/carbed) isn't going to be accurate. The more cars you try to apply the standard correction factors...the more it will deviate from an accurate result.
Actually dynos are no different with its correction factors. Then again a dyno chart by itself is just an illustration of power output. There are such wide variations in dynos which cause results all over the place.
People should look at it the same way... the 1/4 mile correction factors are a useful tool to determine if a mod made more power...or was it just better weather/air that gave you more trap speed. For instance if you ran an 11.5 @ 121mph in 90 degree heat and high humidity...etc...and re-ran in 65 degrees with low humidity you should expect something in the neighborhood of 11.35 @ 123mph. Now if this car with significant mods ran an 11.45 @ 121.5mph in the cooler weather...the corrections would tell you that the mods aren't working the way you expected them to perform. Once again it helps the user define the potential and create an expectation...but not always an accurate one.
Tom
Old Oct 7, 2008 | 04:15 PM
  #1046
TMC M5's Avatar
Andy....trust me don't challenge Ahmad in this area...you will look very foolish...
Tom
  #1047
MHP's Avatar
MHP
'09 C63 AMG
Tom
That's exactly what I'm saying Tom. Corrected numbers aren't the word of God so to speak but they are better than uncorrected for the reasons you listed above. Hell must've frozen over because we finally agree.
Old Oct 7, 2008 | 04:17 PM
  #1048
TMC M5's Avatar
Great a sign of the Apocolypse..... everyone...hold on tight.....
Tom
  #1049
MHP's Avatar
MHP
'09 C63 AMG
Tom
Tom,
I made a statement that cannot be disproved (scientists try to eliminate as many variables as possible when conducting an experiment) based on my own personal experience. In no way shape or form did I say I was a scientist, so please don't try to create extra drama for no reason.
Andy
Old Oct 7, 2008 | 04:18 PM
  #1050
MHP's Avatar
MHP
'09 C63 AMG
Back to work. TTYL guys.
