e63 Sparkplug upgrade?
Old Sep 29, 2008 | 09:14 PM
Fr33kn63's Avatar
E63 AMG
Other then calling up MB to get stock replacement plugs anyone have any experience or suggestions with the replacement of these?
Anyone know whick ones are used stock? part number?
I need 16 of these right?
Thanks for help!
Old Sep 29, 2008 | 11:20 PM
MB Fanatic's Avatar
4 wheels
The E55 needed 16 plugs. I think the E63 only needs 8 plugs. You should look into some Denso Iridium plugs. NGK also makes Iridium plugs.
Old Sep 30, 2008 | 08:27 AM
Fr33kn63's Avatar
E63 AMG
seems neither of them according to their websites makes plugs for my car...oh well.
Just spoke to My dealer and I only need 8, not 16 like the 55's and as usual I will just have to replace with a Bosche OEM plug. Dealer doesnt even carry these. He said he could have them next day for me but none in stock
So they want $18 each for these...
Crazy to think my 2007 already needs new plugs. Even guy at dealer seemed a bit suprised, but all my issues/symptoms seem to point that they might be wearing out. At very low initial loads under throttle you can hear the firing timing a bit slow as if one or more of the plugs are wearing out. until a couple thousand miles ago this never happened. Also idle had become a bit rough. Car drives fine once you get above 2k rpm. Also getting a very mild smell which could be from poor firing of the plugs...not sure if the smell is totally related but gonna find out!
Gonna have them installed tomorrow on my freinds lift. Hopefully this resolves this issue
Old Sep 30, 2008 | 08:28 AM
Mathmik's Avatar
14-F Sport, 07-CLS63 2003-HUMMER 2004-Suburban 2008-MAX 2005-YZF R1
I had some plugs put in my Lexus yrs back ... they were called Torque Master they gave my LEX more power then the Denso or NGK. Not sure if they make them for our cars tho!!
Old Sep 30, 2008 | 12:24 PM
Vadim @ FD's Avatar
S600TT, R350
Fr33kn63:
Highly unlikely it is your spark plugs.
Possibly a bad coil. A STAR scan should reveal which cylinder is mis-behaving.
Stock plugs are good for at least 60K if not more.
Good Luck!
Old Sep 30, 2008 | 01:57 PM
Fr33kn63's Avatar
E63 AMG
Originally Posted by Vadim @ VRP
Fr33kn63:
Good Luck!
even running pretty rich? Hmm wonder if I can find someone around here other then the dealer which could plug it up and take a look.
Well I ended up ordering the plugs. I guess its only 8 in this car. And a freind is gonna help me install tomorrow. At this point just want to take that out of the equation.
Anyone know somone with a star diag machine around Northern VA that could hook it up and tell me which which cylinder is misbehaving?
Old Sep 30, 2008 | 02:21 PM
qat's Avatar
qat
04 e55
Can't you take to dealer for warranty work?
Doubt its the plugs- they are not like the old school plugs that wear- platinum plugs usually last at least 50k miles.
Old Sep 30, 2008 | 02:33 PM
Fr33kn63's Avatar
E63 AMG
I could but going to my dealer has proven they have no earthly clue how to diagnose problems other then to keep my car weeks at a time for warranty work when they start fishing. They also just start replacing parts at random and then I have no clue what else they are messing up. I also have renntech ecu tune and dont want them to reflash which I hear might be something thye would do in this scenario.
I am figuring I am gonna try the plugs since its not TOO much money.
I am also thinking about a retune with my existing mods since I had done my origional tune before my intakes and exhaust work.
There is a group LET tune this weekend in area and am thinking of jumping in on it...thoughts about this ???
would like to find someone with a star diag locally to plug up and figure out if one of my cylinders is messing up.
Old Sep 30, 2008 | 02:44 PM
qat's Avatar
qat
04 e55
I would not risk it- you should take it into the dealer for dealer work and ask them to give you an equivalent loner- you don't want the dealer blaming the aftermarket plugs or its installation, etc. Your car is much too pricey and also under warranty for you to be messing around with it. I doubt its a small problem since the dealer could not figure it out. Most of the time- dealer knows best- and worse case scenario- lemon car.
Old Sep 30, 2008 | 10:02 PM
sack5000's Avatar
2015 AMG C63 S
Take it the stealer and tell them you are going out of town on business and will wait on the car. Tell them not to wash it either. You will be surprised at how fast they get it fixed for you. Putting plugs in the car now sounds crazy. Good luck.
Old Oct 1, 2008 | 03:21 AM
W210AMG's Avatar
2001 E55
you know, if your car is still under factory warranty --< than 4 years and < 50k miles-spark plugs should be covered. just throwing that out there.
of course they will need to verify a fouled plug before dealer will replace any parts.
Old Oct 1, 2008 | 08:21 AM
Fr33kn63's Avatar
E63 AMG
yeah i know. Somehow I dont see the dealer pulling each plug out and measuring the gap of each plug. A slight variation could be enough to cause the engine to not run as smooth. For a few hundred bucks I dont mind spending the money to replace these. Dealer doesnt troubleshoot the way they should. Everything to them is opposite logic and tired of replacing every other part then the ones that might actually need them.
moving forward with this today and gonna have it hooked up to a star diag tool to make sure one of my cylinders aint going bad or having a problem.
If anything new plugs should make it run a little better/smoother.
I appreciate the feedback from all, but dealer doesnt always know best and can prove it with EVERY issue I have had in the last 2 years of ownership. Time to do some stuff on my own since I am modded. The plugs are being swapped out with factory OEM plugs so wont mess up any warranty.
I will update this tonight....
Old Oct 2, 2008 | 04:14 PM
Fr33kn63's Avatar
E63 AMG
ok so had to delay a day in writing this up. Guy helping me do this coudlnt meet up yesterday so he pushed it off til today. Anyway the jury is still out if the noise I have been hearing is totally gone, but my ride home was quiet and without adverse noise.
As far as the spark plugs go....
My car is at 23500 miles. The spark plugs looked like A$$!!! I am gonna try to take a couple pics later and post what they looked like but every other spark plugs gap was off. My gap ranged from .0036-.0042 which I guess in terms of gap is pretty bad. Some cylinders firing hotter then others. NOT GOOD! These plugs are VERY warn. After everything i have been hearing from people I never expected them to look this bad.
The stock plugs as I ordered fromt he dealer for replacement all gapped at .0042 exactly.
Recommendation to 63 engine folk: If you are in the mid 20k miles range and havent had a set of plugs swapped out on your car either do it yourself or go to dealer and ask them to replace under warranty(if possible).
After replacing my plugs I now feel my car is 5-10% stronger at lower rpm's. There is a VERY noticable difference in engine idling feel and under load. Much stronger feel. just my .02
I will update with pictures this evening.
Old Oct 2, 2008 | 10:00 PM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
Wow...kind of surprising. I would have thought these plugs would last longer than 24K miles...ridiculous.
Tom
Old Oct 3, 2008 | 01:22 AM
Vadim @ FD's Avatar
S600TT, R350
Pixs please.
Old Oct 3, 2008 | 07:49 AM
Fr33kn63's Avatar
E63 AMG
Pixs please.
sorry battery died on me last night when i went to take a few pics. Will post a little later this morning.
Old Oct 3, 2008 | 09:28 PM
Fr33kn63's Avatar
E63 AMG
ok here are the pics of my plugs that came out a couple days ago at 23500 miles
Attached Thumbnails e63 Sparkplug upgrade?-1.jpg   e63 Sparkplug upgrade?-2.jpg   e63 Sparkplug upgrade?-3.jpg
Old Oct 3, 2008 | 10:40 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Unusual reach configuration on the '63 plugs. Where you able to source aftermarket pieces?
Their coloration looks to be a little dark, but that could be due to extended idling or an engine that wasn’t fully warmed up and/or run on the highway before swapping them out. Surprising amount of deposits evident. Is it consuming any oil?
Perhaps it simply needs to spend more time in its element - at WOT.
Old Oct 3, 2008 | 11:23 PM
Fr33kn63's Avatar
E63 AMG
Car is driven on hwy daily. And was driven more then 45 min on hwy before swap out. Engine has never had a consumption problem with oil. No couldnt find anything aftermarket so just got a fresh set from dealer and gapped them all to same specs. Car is running much stronger now then before. I tend to go WOT fairly often.
Old Oct 4, 2008 | 01:32 AM
MB_Forever's Avatar
E63 P30, CL500 Sport
Thanks for the pics, but it doesn't look too bad
Old Oct 4, 2008 | 02:22 AM
rarfinancial's Avatar
CLS63
What do you think Vadim
Could New plugs make it stronger? Could the gap have been set wrong? They come preset. Sure we can wait 10k miles for an oil change but I always change at 3k the newer the oil the better Maybe some one should DYNO before & after new plugs.
Old Oct 4, 2008 | 09:24 AM
amusa's Avatar
16 GLE400 4matic
I had almost the same issues. MB found out 1 of my cylnd was missfiring so they ended up replacing the plugs. Till now the vehicle shakes a bit when normal ideling on start up. I had them check the coil packs they told me it's fine. Now I'm out of warrenty. Now I'm thinking to dump seafoam or do that BG thing
Fr33kn63's Avatar
E63 AMG
Thats not too bad an idea. the plugs look terrible. Gaps were off all over the place deposits/corrosion all over the arcs.
My recent Dyno sheets under the 63 thread are from about 2 weeks ago with the bad plugs. might go back to the Dyno this week and rerun it on the machine to see if there is any difference in numbers. Gotta see how busy my week is. The following monday I am going to MIR to do some runs.
Car definetly feels a lot stronger in the first 4-5k rpms with the new plugs.
