oil consumption between changes?
BTW, FYI oil drain plugs (2) are a one time use item in the E55, they must be replaced once removed from pan.
How much are you losing? Are you burning it or is it leaking? Trust me, I have researched and BOTH bolts are to be replaced, not just the washers.
I don't see or smell any oil burning and I never see any leaks in the driveway. Car runs very strong too. Any suggestions?
I have friends with M's that say the cars drink oil too. But, they run like a champ. I wouldn't worry about it. It's very common on a lot of high hp cars.
My E63 doesn't use any oil between changes. But I know another owner who uses a lot of oil. It's the same motor. We both drive similarly. The same with M owners I know. Some use oil, some don't. Same with Porsche. It seems to vary all over the place.
New 997.2 Porsches are varying a lot from specimen to specimen and PCNA responds only by giving a range of miles per quart. Same with MBUSA and BMWNA.
Just curious......
Just curious......
But now it uses no oil at all and runs really strong. No tappet noises or anything, either. I'm pretty confident the motor will outlast the car itself.
Just curious......
I don't get it either. Maybe, because each engine is hand built then dyno tested immediately. Could cause variation from motor to motor. My car burns a little oil but it's significantly faster then my buddies who doesn't. Every time he drives my car he says it feels stronger and sweeps through the rpms quicker then his e55. I'm satisfied with that.
