Air Intake Question
Here is the text from the website:
My only modifications, which boosted the power from 469hp to approx 505hp, was to swap in the SL55 air intake snorkel and add K&N air filters. The far more expensive SL55 (using the same engine) was rated at 493hp and Mercedes claimed that a more restrictive exhaust system cut the power in the E55 but the true story was that the decrease in power was due to a $5 plastic restrictor in the intake system which took less than 10 minutes to swap out. The K&N filters provided about 12hp too.
http://www.derekspratt.com/HTML/Auto...cedes_E55.html
Thanks,
mbmaxx
04' E55
01' Harley Deuce
We have lots of dynos with the stock guys pulling a tick over 400whp average. Even with 19% loss which is a bit high that is close to 500hp.
https://mbworld.org/forums/showpost.php?p=1960189&postcount=9
Since no one as ever been able to post any proof that the engine becomes starved for air or produces less power as a result of this slightly smaller opening, I view both the hole size and protective flaps as a non-issue. Just do the S55 driver side tube, and you're good to go.
