*** VRP X-pipe Holidays Special ***
With new suppliers coming on board our resonator replacement X-pipes are coming back in stock. To celebrate the occasion we are glad to offer special pricing.
Regular $549 - on SALE for $449 - SAVE $100.
Our X-pipe is designed to directly fit CLS/E 55s and 63s, with exception of Station Wagons, it is made from stainless steel for long life and specifically made for W211/C219s.
On 55s it adds a bit of low end burble, on 63s it wakes the exhaust note without replacing exhaust system.
Here are reviews by other members.
https://mbworld.org/forums/showthrea...ghlight=x+pipe
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
They have an exhaust guy that I really like. He does meticulous work and loves to explain his craft. He was the one that fixed my leak and we started to talk about ways to get more out of the exhaust. He recommended against changing out the 2.75" piping for 3", which saved me a bit so i thought we would see what else he could do.
As far as X-pipes, in general, you are always trying to find the proper angle and mixing hole. You are basically going from the extremes of straight pipes all the way to an H pipe, depending on the entry and exit angles. In my case, we tried 3 setups including an H-Pipe just to get a feel. I liked the straightest angles possible. Why? I think it is because that setup has less resistanse and tends to add the best turbulence at higher velocities. I hope that means that I get the best scavenging at the top end. The car is already a beast down low, so i am not looking to tune the exhaust to help my 60'. I want more top end.
Hope that helps. I am getting full sets made from them (including headers) in the next few weeks, so I can give you better measurments soon.
I hear they have some great AMG products at great prices.. VRP's X-pipe has a great sound
