How the heck do you re-set the analog clock??
Old Nov 15, 2008 | 07:43 PM
marcmc8867's Avatar
'15 S550 4Matic, '15 GL550, 360 Spider, Escalade ESV
I've tried a couple times since DST ended and I can't seem to figure out how to adjust the analog clock in my E55. I can do the digital one via the display but I'm not finding where to adjust the analog despite looking in the owner's manual.
If it is super obvious, I apologize in advance. My Ivy League education may not be all it's cracked up to be
Thanks!
Old Nov 15, 2008 | 07:54 PM
slavik's Avatar
g63
it is in system menu under settings time/date.... once you pick your time hit the R or reset button and it should work...
Old Nov 15, 2008 | 08:49 PM
E55Killa's Avatar
E55 AMG
where is the R? the right paddle shifter on the wheel?
Old Nov 15, 2008 | 09:12 PM
Serenity Now's Avatar
03 E55 AMG
By "R" I think he means the reset button left of the display.
Old Nov 15, 2008 | 09:16 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Read the Comand manual. Setting the clock is tied to GPS via COMAND.
Old Nov 15, 2008 | 10:27 PM
E55Killa's Avatar
E55 AMG
ahh.. Appologies im a new owner only a month in
Old Nov 15, 2008 | 11:44 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
That is an optional settings (albeit default typically).
You should see a setting under the Settings menu under Date and Time and there will be an option there to "Sync with Head-Unit." Select that and it will sync with your COMAND via GPS.
Otherwise, proceed through the menu and set the time (if you want to do it manually) and press the Trip Reset button to confirm it.
Old Nov 16, 2008 | 12:53 AM
rarfinancial's Avatar
CLS63
Command center. I had the same problem a few years ago
Old Nov 16, 2008 | 01:01 AM
str8ridin's Avatar
05 E55
Are you telling me that there is a way to display a digital clock on the navi screen? Or are we just talking about the ETA display?
Old Nov 16, 2008 | 01:32 AM
Polar Bear's Avatar
No - there is no way other than pressing the SERV button and Time. This will allow you to adjust the time as the COMAND needs to know the current time to project ETA, but will not display it for reference.
Old Nov 16, 2008 | 02:00 AM
jerryho's Avatar
bmw
Press the SERV button to the left of the navigation screen. Then set the time. Now make sure that the option "Sync with head unit" is turned-on -- this option is found in one of the menus when you use the menus selector on the steering wheel.
Old Nov 16, 2008 | 08:19 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
One other feature that becomes activated when "sync with head unit" is on, is that when you cross a time zone the analog clock in the instrument cluster immediately updates.
