Famoso Track Rental - Saturday 01/17/2009
#1051
2004 MB E55
Try Summit or Jegs, usually under $150. I've installed quite a few line-lock kits only theyv'e been on GN's, F-body GM cars and my Supra, but never a Benz. Would be cool though.
#1054
MBWorld Founder
ones too fast according to CHP!
Cool - lots of interest. I figured there would be. It is a cool mod.
If you can leave the car for the day, it is no problem.
Thanks for the explanation and the support! I know you guys love it.
Nope. In fact, I will explain the way they work:
1. Pump up the brakes (on a MBZ, one or two firm presses on the pedal)
2. While holding the brake pedal down, activate the switch (a momentary switch)
3. Release the brake pedal
The solenoids on the front lines will hold the pressure in the caliper as long as you hold the switch. The rear brakes have no pressure and you are free to hit the throttle and do your burn-out. As you are ready, release the button and you will start to roll-out.
The complete kit is $395. This includes:
- Two High Quality Line Lock Solenoids that are compatible with the high pressure MBZ system
- Stainless Steel braided and Teflon coated brake lines
- 4 Adapters that allow this to be installed with the unique (Mercedes makes it as hard as possible) brake line fitting used by the factory
- Required length of wiring, with fuse holders and fuses
- Momentary switch with coiled cord that can be hidden in glove box (this can be upgraded to removable with a plug). This switch is the same that was used in the Abrams M1 tank as the fire button FYI - heavy duty!
I will take some pics this week.
Yes, for generic solenoids, that is about right. But the fittings, switch and lines that allow you to use this on your Benz add quite a bit unfortunately.
No and no.
lol - late for sure. You can all thank sticky as he was the one that got me doing these.
Brad
Brad
#1055
I thought for whatever reason that the CLK BS was almsot as heavy as an E55. What sort of things have you done to lighten that car? Subtracting my body-weight (plus helmet, etc.) from my standard track weight yields 4,175 lbs on the scale - 389 lbs more than your BS. That is some weight savings. Then again - when we start talking about 3800 lbs being "light", it has to make you laugh.
#1056
#1058
#1061
Hey Brad, do you have these vids in any other format? Quicktime SUCKS, adn it won't let me change to a different MPEG default viewer...Might as well be running these on a 286 with dial up LOL!
#1062
CLS63
#1064
MBWorld Founder
1. right click and "save to computer"
2. open/play with Windows Media Player or better yet with the FREE Divx player
These vids are encoded with Divx in order to keep them small for the large screen resolution that they are (640x480).
If anyone has any problems after trying this, let me know.
thanks
Brad
#1065
OK, let me make it easier.
thanks
Brad
thanks
Brad
#1066
MBWorld Founder
they are .avi files, not MPEG. you are DL'ed the photo I used to show what the video is. Try right click and "save LINK as"
OR
Call me, I can walk you or Rich through it.
Sorry.
PS - tried Youtube, vids are too big.
OR
Sorry.
#1067
E63 P30, CL500 Sport
when you right-mouse click on the video, choose "Save Target As...." not "Save Image As....." and this will save the avi file on to your computer. Then open up Windows Media Player and go to File --> Open and then choose the avi file you just downloaded. If you don't have the appropriate codecs, it'll let you know you need to download them, but all new Windows Media Players now come with an inclusive codecs pack that can play most avi files.
#1068
Jim, if you're using Internet Explorer.....
#1074
2004 C32 - Stock
#1075
been gone for a while & didn't see all these videos great work
