Removed Charcoal Filters
Hello Guys,
I removed my charcoal filters today, i unplugged the two sensors that are connected to the airbox, took out filter and refitted. I then reassembled everything , made sure everything was connected properly. It feels like it has more oopmh! anyway to the point, car drives fine and everything, but a hour later a got a Check Engine Light, could this be related to me taking the charcoal filters out or a whole other matter? car just got back from dealership with a service D.
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
Not to be rude or anything but if you pulled out the charcoal filters then you got a cel- it's pretty obvious that the removal of the charcoal filters is causing the cel. Reset the cel and see if it comes back on, if it does- put the filtes back in and reset it again and see if it comes back on. Do you have a code reader?
I have a service appointment on the 30th, they are giving me new wheels to replace the current ones as they are starting to flake. Anyway so should i try to find the fix on these forums, or tell the dealer my CEL came on? also if i take it in should i put the filters back on ?
I would recommend putting the filters back in then just telling the dealership that the cel's came on after you picked the car up from their servicing it.
It is a standard On Board Display II (OBDII) hookup and it is just up under the dash by your left knee. There should be a little red flip door to access it and the cable simply snaps in. Very simple.
NOT On Board Display
once again slinging the terms without understanding them...
What a turd! Lets let the OP say who has been more helpful, ok? You with your perfectly mechanic head or me with my enthusiast know nothing? Attitude is everything when it comes to contributing. You offer jack!!
