Offset Concerns on 20" wheels - Please reply asap
Rating: Thread Rating: 2 votes, 5.00 average.
Old Feb 2, 2009 | 07:14 PM
Wellsy's Avatar
2004 E55
E55 AMG Wheel Fitment - Need Help asap
Hi all
I have been offered the Monarch 63rs wheels.
They measure
Fronts 20x9 (ET35)
Rears 20x10 (ET45)
Will they fit a W211 E55 with a drop of 1.5"-2.00" drop without any problems?
I need to let the guy know tomorrow so a quick response would be great.
Thanks in advance for your help.
Also posted in Technical, Wheels & Suspension
Old Feb 2, 2009 | 08:40 PM
jangy's Avatar
2015 S212
The rears may be a hair too high. Be careful with wider tires; they will rub on the inside before the outside on that offset.
Old Feb 2, 2009 | 09:07 PM
drop997stop's Avatar
08 E 6point3-sold- 11 caddy cts-v-sold, 2012 E63 Palladium Silver
ooo
Jangy, I think your wrong on the 45 et. I thought the higher the offset the less aggresive the fitment.
I am thinking that the 45 offset is not aggresive enough- most e55 fitment wheels have offsets in the high 30's
Old Feb 3, 2009 | 08:41 AM
psoas's Avatar
09 jeep srt8, 07 gl450
Jangy is correct.
45 is about 10mm from optimal ~(35et). They would sit inward.
The rims that come from a CLS have offsets of ~25et, and as we have all seen, those tend to stick "out" more than ideal by 10mm.
Old Feb 3, 2009 | 11:33 AM
Wellsy's Avatar
2004 E55
Thansk psoas, jangy and drop997stop but I am still confused which isn't difficult somedays,
I have seen a set of similar/same wheels on an e55 w211 that have ET32 front and ET42Rear. http://mymbonline.com/forum/viewtopic.php?t=7&start=50
The wheels I am buying are ET35 front and ET45 Rear.
Does this mean that the will be further inside the arches and scrubb the insides or further outwards so the might catch on the arch edges/lips.
Please attempt to calarify as i am unsure.
Old Feb 3, 2009 | 11:36 AM
Wellsy's Avatar
2004 E55
Here is the E55 that has the et32 fronts and et45 rears
Attached Thumbnails Offset Concerns on 20" wheels - Please reply asap-e55monarchwheels.jpg
Old Feb 3, 2009 | 01:00 PM
Vic55's Avatar
Administrator
A 10mm spacer would bring that to 35mm and ensure clearance on the inner well. The only way to confirm is to mount the wheel or find someone on the board with the exact same wheel. Doesnt Godfather have Monarchs???
Old Feb 3, 2009 | 01:43 PM
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
My rears are ET44, and i used an H&R 10mm Spacer to bring them right to the fender, which i believe makes them an ET34.. No rubbing at all.. My fronts are also ET34
Old Feb 3, 2009 | 04:43 PM
jtc55's Avatar
08 E63
why don't u just ask the seller if he's running rear spacers on his E55?
Old Feb 3, 2009 | 05:54 PM
Wellsy's Avatar
2004 E55
Guys, lovin the help..... its much appreciated for sure.
I think I have now got my head around this offset thing.
I initially thought that if the ET value increased there was going to be a higher likelyhood that the wheels would stick out from under the arch and cause rubbing on the arch edges/lips and that I would need to have the wheels machined to move them back under the arches.
It appears to make more sense from the help you guys have given and osidian05e55 comment confirmed that at worst a spacer could remedie any inner arch rubbing.
I will buy the wheels tomorrow and will invest in some suitable spacers.
As soon as they are on the car I will get some pictures posted.
Thanks again all. Regards. Mark
Old Feb 4, 2009 | 10:37 AM
Wellsy's Avatar
2004 E55
They have arrived !
they are super sexy
The offset on the rears is different to what I had expected.
The offset on the rears is ET38.
Do you think they will be OK?
Attached Thumbnails Offset Concerns on 20" wheels - Please reply asap-p1013729-3-compressed.jpg   Offset Concerns on 20" wheels - Please reply asap-p1013732-3-compressed.jpg   Offset Concerns on 20" wheels - Please reply asap-p1013735-2-f-2-compressed.jpg   Offset Concerns on 20" wheels - Please reply asap-p1013734-2-f-2-compresed.jpg
Old Feb 4, 2009 | 10:45 AM
W219CLS55's Avatar
06' E55, 10' Harley Davidson F-250 6.4L TT
Very Nice looking wheels
Old Feb 4, 2009 | 11:14 AM
ohlord's Avatar
When in doubt
Always check your measurements
http://www.1010tires.com/tech.asp
With the proper hub centric spacers those rims can be made to fit.
Your ride is going to suffer,you will need to watch out for every pot hole in the road,every stock E55 will wax you in the turns,your tires will be far to - negative in camber from the 1.5-2 inch drop so be prepared to buy new 20 inch tires frequently unless you budget now for the proper suspension parts to bring the alignment into spec for that drop.
First enjoy the new rims ,then you can address the other much more major issues.
Those 10's are going to be a tight fit,no matter what you do.
Old Feb 4, 2009 | 11:23 AM
Old Feb 4, 2009 | 12:08 PM
Vic55's Avatar
Administrator
They have arrived !
they are super sexy
These are the same wheels that Godfather has on this site. If the offsets are standard (not custom) then im sure you will be fine since he has slammed his car. Do a search for his posts- most should be on page 1.
Old Feb 4, 2009 | 02:13 PM
harjothundal's Avatar
05 e55
here ya go
https://mbworld.org/forums/w211-amg/...exclusive.html
https://mbworld.org/forums/w211-amg/280172-godfathers-rides-2002-today-epicness.html
Old Feb 4, 2009 | 02:39 PM
Vic55's Avatar
Administrator
Thanks!!!
Old Feb 5, 2009 | 03:48 AM
Wellsy's Avatar
2004 E55
ohlord..
Do you think I will need spacers on the front or on the rear.
I think the standard offset on the rear is ET39 and I have ET38 so is that going to work without any spacers?
The standard offset on the front is ET30 and with the wheel I have being ET35 I think I may need 5mm hubcentric spacers / regular spacers.
Any ideas?
Old Feb 18, 2009 | 08:34 PM
OJwerks's Avatar
not stock.
ohlord..
Any ideas?
dude people have answered you many times and you keep asking the same questions
"recommended" offsets for the rear are ET35 when running THAT size in particular, offsets vary depending on the size of the wheels ... I dont think you would have any trouble running them at ET38 ...
Old Feb 18, 2009 | 09:56 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
Got em on my 55, 2 inch drop, everything fit fine. I did put a 3mm spacer on the rear because the caliper clearance was like 1mm.
Old Feb 18, 2009 | 10:24 PM
dpavid's Avatar
2005 AMG E55
same for me... 3mm spacer for caliper on rear only. No drop on my E55.
Old Jun 21, 2009 | 12:02 PM
CooperTurbo's Avatar
CooperTurbo
Íàðîä! ïîìîãèòå!
Ó ìåíÿ N16 ñåäàí. Ðàçäðàæàþò çàäíèå ôîíàðè. Îäèí áåëûé, äðóãîé êðàñíûé! Íà Sylphy ñ ýòèì âñ¸ íîðìàëüíî! Âåçäå òðåáóþò ÂÈÍ! À ñêàçàòü ñîîòâåòñòâåííî íå÷åãî.Ïîäñêàæèòå íîìåð ôîíàðÿ íà êðûøêå áàãàæíèêà ëåâûé... èëè ãäå åãî ìîæíî ïðèêóïèòü!!!Äëÿ ïðèìåðà çäåñü http://sylphy.ru/forum/sylphy/moding.../fonri-zadnie/ âàðèàíò òîëüêî ÄÅÏÎ!!
Old Jun 21, 2009 | 12:22 PM
Busta Riles's Avatar
1969 280S, 1991 300E
I've been runing the same wheels on my 55 for over a month, no spacers, no problem.
The clearance on my rear calipers is 0.6mm....the calipers don't move, so they will never touch.
Old Jun 21, 2009 | 01:11 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Rather too much offset + spacers than too little offset and rubbing on fender...
Too much offset can be fixed too little can't.
Old Jun 21, 2009 | 01:14 PM
jangy's Avatar
2015 S212
OK. Many think I'm wrong and they are probably right. I hate 20s and spacers so my opinion on this thread is worthless anyway...
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
