Old Jun 15, 2015, 07:50 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Electrical Guides
Print Wikipost
DIY Valve Cover Gaskets, Plugs, and Plug Wires
Old Aug 7, 2010 | 12:44 PM
Forrest Gump 9's Avatar
shrimp boat
Originally Posted by 99w210
I'm trying to do replace the valve cover gaskets. How do we reseal the vent chamber?. Is there a gasket?. -- I've called the dealer parts dept and they do not see any gasket for the vent chamber.
Thanks,
Just use some silicon gasket maker material. That's what I did and it's been fine.
Old Aug 8, 2010 | 02:25 PM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
I am going to need to do this since apparently one is leaking slightly. Got a link to the plugs and wires you bought? Thanks.
Aaron
Old Aug 8, 2010 | 03:04 PM
99w210's Avatar
99 E320, 05 E55
Thanks to this DIY section. I've replaced the valve cover gasket.
What I've noticed is that the vent chamber was also part of the leak. So, using the suggested Liquid Gasket, I've re-sealed the vent chamber.
Last edited by 99w210; Aug 9, 2010 at 11:48 PM. Reason: Not sure if I could post an external link.
Old Aug 9, 2010 | 10:46 AM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
Thanks,
There is no rubber gasket for it, clean off the old liquid gasket and apply new liquid gasket.
Old Sep 20, 2010 | 08:50 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Those cam covers cam out a treat
Old Sep 21, 2010 | 12:26 AM
harjothundal's Avatar
05 e55
https://mbworld.org/forums/w211-amg/...asket-diy.html
I would like to add to this DIY... I found this thread when my gaskets were leaking, and changed them both out... However, my mechanic didn't reseal the vent chambers nor did I ask him too... Fast forward a few months and the passenger side vent chamber was leaking... It was simple to do, click on the link above if anyone else may be interested in doing this as well...
Old Sep 21, 2010 | 09:08 AM
  #32
chawkins2001's Avatar
2006 E55 AMG
Are those Evosport Headers? They look to be very nice.
Old Feb 10, 2011 | 12:43 AM
  #33
ahmad0658's Avatar
Brabus K8 E55 05
Is there any way to know what letter each wire of the Evosport is? I lost the tags on the wires while the workshop doing some work on my car
Can anyone help please? I have the wires but none tags and I don't know which one is K, L, etc ...
Old Feb 14, 2011 | 08:48 PM
  #34
tbal's Avatar
Haters crazy
Did you disconnect the line going to the fuel rails? The metalish pipe doesnt seem to have so much give and I cant seem to take the valve cover off...
Help!
Old Feb 14, 2011 | 09:11 PM
  #35
grantwoodtx's Avatar
GLE 63S
Help!
Yes you need to remove the braided fuel line to get the cover off on the drivers side. Undo it slowely and have a towel underneath it, unless the car has sat for a while there will be some fuel under pressure. Also remember the aluminum tube on the very right of the cover make sure it pokes back into the grommet in the SC plenum otherwise you will throw a code.
Old Feb 14, 2011 | 09:26 PM
  #36
tbal's Avatar
Haters crazy
Thank you! I realeased some of the pressure from the fuel rail pressure check valve. I'm a bit confused and now scared lol about this aluminum tube. Can't see it...
Old Feb 14, 2011 | 09:27 PM
  #37
WHTEVO's Avatar
+1
I tried to leave the fuel line on and it just wasn't happening with it on.
That aluminum tube almost made me pull my supercharger crap apart. The tube came out of its grommet which is under everything and can't be seen. I didn't know there was a grommet originally and was getting pretty upset as it causes a pretty big vacuum leak. I was lucky enough to get it back in without disassembling anything. I just kept pushing it in the area where it goes. Just take your time and you'll be alright.
Aaron
Old Feb 14, 2011 | 09:29 PM
  #38
WHTEVO's Avatar
Its the tube that runs along the side of the body of the car parallel with the valve cover on the driver side and it turns into and goes under the intake plenum area near the throttle body. Just don't pull on anything and you'll be alright.
Aaron
Old Feb 14, 2011 | 09:47 PM
  #39
GLE 63S
You need a mirror to see where it would fit back in to the plenum as EWHITEVO said I poked it in there and got it in first time.
Old Feb 14, 2011 | 10:00 PM
  #40
tbal's Avatar
Haters crazy
I sound like such I newb but I still don't see it lol how will I know I pulled it out? Pix of approx location?
Old Feb 14, 2011 | 10:17 PM
  #41
Tibi's Avatar
03 Silver E55
I am not sure what that tube is for. But you may not have it. My 03 E55 doesn't, and the cap on the snout is a sealed end. But my 03 C32 had that tube. The only 04 E I have wrenched on had it but at the time I didn't think to figure out what it was at the time.
Old Feb 14, 2011 | 10:19 PM
  #42
Tibi's Avatar
03 Silver E55
Well I don't sound like I have been drinking at all.
Old Feb 14, 2011 | 10:20 PM
  #43
tbal's Avatar
Haters crazy
Thanks!
06 here... dont see it either..
Old Mar 13, 2012 | 03:43 PM
  #44
gazosnic's Avatar
e46 m3, w211 e55
For reference what are the torque specs for all these bolts / tightening the fuel line etc?
Old Mar 13, 2012 | 06:24 PM
  #45
93RX7LSX's Avatar
93' Ultrasonic Blue Mica LS6/T56 RX7 R1 weekend/ 2007 4Runner V8/ 08' prius
What did your plugs look like at 80k miles? What kind of plugs did you use? How thick are the evosport wires?
Old Mar 13, 2012 | 07:24 PM
  #46
novae500's Avatar
W211
I did my plugs 2 wks ago. Had 63,000 miles at 5 yrs and was better to do than wait 100,000 mikes. Some plugs looked good while others didn't. Several DIY helped with the install. Just make sure no lines are disconnected. Car idles a lot better after plug change
Old Mar 13, 2012 | 07:53 PM
  #47
Dawson718's Avatar
E552004
What did u resealed the vent chamber with.I brought a new value cover and they leak before 20,000 miles.Mercedes value cover is a pieace of ****.I think it will be better just to used silicone.
Old Jul 24, 2013 | 12:18 PM
  #48
xaveon's Avatar
2005 SL55
Does anyone have the part number for the Spark Plugs? I'm trying to do this DIY, but am having a difficult time finding the Evosport wires and the Spark Plugs.
Old Jul 24, 2013 | 02:03 PM
  #49
gazosnic's Avatar
e46 m3, w211 e55
Whats the advantage of replacing the wires if they are not faulty? There are a few different kinds of spark plugs that are popular here. If you search youll find both OEM as well as the bosch, and NGKs that are good.
Old Sep 27, 2013 | 05:17 PM
  #50
E55AMGGG04's Avatar
04 w211 E55
Quick update. I found this. I'm going to put this back in and see what happens after I take it for a spin. Maybe it won't spray out.
Edit: this is an evap hose. It threw my cel a couple weeks ago but never did the oil spray during that time :/
Attached Thumbnails DIY Valve Cover Gaskets, Plugs, and Plug Wires-image.jpg
