*** VRP 82mm TB ***
Rating: Thread Rating: 2 votes, 3.00 average.
Old Feb 26, 2009 | 01:59 PM
  #51
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
100 ftw
Old Mar 4, 2009 | 10:34 AM
  #52
jikjak's Avatar
CLS55 AMG & RRS S/C
any updates on this?
Old Mar 5, 2009 | 01:26 PM
  #53
vrus's Avatar
2003 E55 AMG
Sorry for the delays guys.. I've got a large order pending for these 82mm bodies. I just need to plug them into a few more cars and make sure all the electronics work properly.. Since I dont have an inlet to bolt it to I cannot fully install it and test it on the road.
As long as the electronics check out and the throttle plate moves as expected then I know that everything will be fine when they are installed..
I will make the bodies available once I've had a chance to verify all of this.
Old Mar 6, 2009 | 01:43 PM
  #54
jikjak's Avatar
CLS55 AMG & RRS S/C
awesome! thanks.
i hope they will be ready soon!
Old Mar 13, 2009 | 11:57 PM
  #55
jicl55's Avatar
2003 cl55 (sold)
....more updates, more updates!
Old Mar 14, 2009 | 12:10 AM
  #56
Thericker's Avatar
V12-Biturbo
Was poking around the-Bay found a perfect stocker
Maybe good for some experiments
http://cgi.ebay.com/ebaymotors/Merce...Q5fAccessories
Old Mar 14, 2009 | 09:40 AM
  #57
HYEPWR's Avatar
2011 Black C63 Eurocharged V5
Thericker
lmaoooo....@ your lil peeing guy...
Old Mar 14, 2009 | 11:06 AM
  #58
CWW's Avatar
CWW
SL600
Originally Posted by Thericker
Hey Ricker, do the M275's come with two independent TB's like the M120's do?
Old Mar 14, 2009 | 11:08 AM
  #59
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
by the way that might be the stock TB which is maxed out at 80 if you bore it from what i recall
Old Mar 14, 2009 | 07:52 PM
  #60
Thericker's Avatar
V12-Biturbo
Originally Posted by HYEPWR
Thericker
Old Mar 14, 2009 | 07:58 PM
  #61
Thericker's Avatar
V12-Biturbo
Good Q: I'm not sure....Things I should know...
Old Mar 14, 2009 | 10:12 PM
  #62
MB AUTO RACING's Avatar
2004 E55AMG RENNTECH STAGE 6,2005 SL65 AMG RENNTECH STAGE 3
the throttle body that is 82mm is a 273 engine throttle body and yes the eletronics do work!!! i have it on my 2006 cls55 renntech stage 5 plus 650hp!!!
Old Mar 14, 2009 | 10:43 PM
  #63
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
Enjoy it while it lasts.
Old Mar 14, 2009 | 11:59 PM
  #64
Thericker's Avatar
V12-Biturbo
Ahhh....You gonna tattle
Old Mar 15, 2009 | 09:01 AM
  #65
CWW's Avatar
CWW
SL600
If the M275 is the same design Benz usually uses for their V12's, and like the setup that came with my M120, then you probably have two completely separate 72mm or 74mm TB's, one feeding each cylinder bank. Pretty advanced design.
If that's the case, then the bottom line for your motor is that there's probably no worthwhile gains to be had with larger TB's. Because you have 148mm of total capacity already, your motor would probably need to be pushing 800+hp before that would ever become a real constriction point.
I'm sure there might be some very slight gains to be had with larger TB's, or with a port and polish job, like a couple rwhp maybe. But you'll never see that huge 60hp bump that the 55k guys will, with their 500hp+ motors sucking through a single 72mm-80mm TB, because your motor doesn't have that capacity constraint at the TB in the first place.
If you can verify that your motor does have the twin TB's, then I would skip this mod, it's never going to give you a real bang for the buck.
Old Mar 15, 2009 | 03:17 PM
  #66
Thericker's Avatar
V12-Biturbo
Actually I do remember the 600/65 have the same larger TB 80-82mm. I wasn't looking to mod my TB, just chimed in cause I found the stocker on the Bay
Thought someone might want it..
Old Mar 19, 2009 | 03:36 PM
  #67
jikjak's Avatar
CLS55 AMG & RRS S/C
any updates on the 82mm TB yet?
Old Mar 19, 2009 | 03:37 PM
  #68
jikjak's Avatar
CLS55 AMG & RRS S/C
Old Mar 19, 2009 | 04:12 PM
  #69
jangy's Avatar
2015 S212
Isn't the new Renntech 82mm TB made from the 65 TB and OEM plenum?
Old Mar 19, 2009 | 04:13 PM
  #70
URnext's Avatar
SL55 AMG
LOL. Looks like it already happend.
So any update on the TB? I would like to put the biggest **** on there possible.
Old Mar 19, 2009 | 04:18 PM
  #71
blackbenzz's Avatar
haters crazy
+1.
Old Mar 19, 2009 | 04:42 PM
  #72
Zod's Avatar
Zod
Originally Posted by blackbenzz
+1.
no its not
Old Mar 19, 2009 | 04:44 PM
  #73
blackbenzz's Avatar
haters crazy
Originally Posted by Zod
no its not
I wasn't saying it was. I was asking. So where is it from then? Renntech is very well known for recycling AMG parts
Old Mar 19, 2009 | 05:33 PM
  #74
jangy's Avatar
2015 S212
no its not
Can you elaborate because the one I saw looked like it and I am not talking about Angelas.
The E55 plenum had been modified to mount to the 82mm TB that was definitely an MB part.
Old Mar 19, 2009 | 06:29 PM
  #75
Thericker's Avatar
V12-Biturbo
I do know the 600/65 share the same 80mm TB, now where the 82mm evolved is anyones guess
URnext
Yeah big-red tattled
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
