ASP 180mm Pulley from LET
Super Moderator
You will hear the blower whine like no tomorrow! I have a 180MM from HYEVON Motors and everyone always tells me my car whines like no tomorrow when I get on it. It's intoxicating I tell you!
Super Moderator
I'll be getting one done very soon! I'll keep ya posted ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Thanks Alan!![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Yup. I have a lil extra kick for my cooling set up but the upgraded H/E and the CM30 is good enough for daily...
Thanks Alan!
Former Vendor of MBWorld
W211 E55
SL55 AMG & BMW F10
yea i no it works better with a tune bit i just want to no what 2 size pulleys let have and how much boost over stock do u get from the pulleys
W211 E55
The LET pulleys are 172mm and 180mm.
There's about a 1.6 PSI difference between the two, measured from a tap in the surge tank.
Absolute PSI measurements depend on the parts installed on the car, since it is a measure of restriction. A free-flowing setup will register less overall boost but make more HP and less heat.
2015 S212
In a highly restrictive setup, the blower will generate more pressure (psi), but will also have inefficiencies (heat) that make the power gained a function of diminishing returns. In the end, you may have 16psi that generates Xrwhp but also adds much heat.
In a low restriction setup, the psi will be low even if the pulley is huge and spinning hard because it has nothing to "push" against. In this case, the SC may not make as much heat but instead the air doesn't flow well so we lose in efficiencies.
I'm in the process of openning up as much airway as I can with the hopes of finding that sweet spot. I have been hunting for a huge TB for a while since that is the big "restriction" in my car. The point comes though, when the car gets lag from all of the free space that it has to compress each time...
2008 A8L, 2002 996TT X50, 2009 X5
FWIW, you will also notice substantially different actual boost levels in different atmospheric conditions. Datalog at sea level in dry 45 degree air, and again at 2000 ft in humid 80 degree air, and you'll observe dramatically different boost measurements recorded.
1 Post
W211,E90,E66,E39,E38,NSX,Z32-TT
If I add VRP shortie headers, but keeping the stock mid pipes and exhaust will it be a good start than stock headers? Will I need a re-tune of the ECU once I add headers?
