Front brake rotors and pads: Where to Buy?
If upgrade, get the EVOsport Rotors and aftermarket pads. There is another thread open now on the best pads. In summary, it looks like the EBC pads are good for noise (after break in) and dust. There is debate over which pad performs the best, but i am assuming you want low dust more than anything.
If not upgrading, there was a company that sold cross drilled rotors for our cars at a very reasonable rate. PM Benzorama and see if he can help.
Sounds like you may want the EBC pads then, since they were cheaper and less dusty.
Only problem is I keep getting this random sqeaking in reverse from the rear wheels every few months, and I did an extensive bedding run over the 2 days after I put them in, so it can't be that. When they start squeaking again, I have to go slather on more anti-squeal paste and then it goes away for awhile. But the pads perform VERY nicely, and I love the lack of dust.
Parts.com had the best price for rotors and pads were from http://partsfactor-com.amazonwebstore.com
Pat numbers are:-
Akebono EUR984 Rear Ceramic Pads
Akebono EUR983 Front Ceramic Pads
Thanks...
I'm from San Jose and I'll be visiting LA in the next few weeks visiting in-laws. If you decide you want to buy them let me know and I could bring them up and save you the shipping.
I believe you should get way more then 13k on the life of the rotors. I'm sure someone will chime in on this and give you a better approximation.
Basically for my info,
1. I dont have to disconnect the battery.
2. Pop the hood and disconnect the SBC.
3. (Should/Do I need to) Place my key fob far from the car and close all the doors?
Any other tips, and what brand of brake fluid are you using or is any Dot 4 ok to use?
