Eurocharged 172mm pulley group buy
Old 03-25-2009, 03:00 PM
  #51
AZIPOD's Avatar
W211,E90,E66,E39,E38,NSX,Z32-TT
Originally Posted by kipper215
I am curious about drivability with a 180. Is it ok to have a 180 for a daily driver. will I have a lot of lag. Or is it better to go with a smaller size. I will be getting the HE and pump. also I see that with the spearco HE there is no 7 inch. you can never be too efficient so, can I get the new core in 7 inches so I can have maximum cooling. coming from a highly modified car I found having a great intercooler is key to getting good numbers and a better margin of safety.
Code 3 uses a Spearco Core. It is a 5 inch, they said it is very efficient so they scrubbed designing the 7". It would be nice to get a 7" though -- im not sure who makes it..?
I have a 180 .. no driveability problems, but serious power. Initially, I thought there was a lag, but another member on the board expalined it quite well to me .. I dont think I have a lag.
Old 03-25-2009, 03:46 PM
  #52
jikjak's Avatar
CLS55 AMG & RRS S/C
can u explain more about the 180mm?
if u dont have lag then what is it?
also more details on how it drives.
im also considering going to a 180mm (i have a 168mm atm) after upgrading my cooling.
Old 03-25-2009, 08:09 PM
  #53
squidj's Avatar
2006 E55 (white); 2016 GL 550 (white)
Guys, I plan to drive from NC to Elpaso, Tx this summer in the Beast. I will be out there on business for a while. If I get this pulley set and just use my stock cooling system do you think I will have cooling issues? Or should i just leave the car stock?
Old 03-25-2009, 08:15 PM
  #54
aleksandar1099's Avatar
Mercedes
With the 172mm you will not need cooling upgrades,
with the 180mm it is absolutely necessary
Old 03-25-2009, 08:31 PM
  #55
squidj's Avatar
Thanks, I have actually already had the car tuned before by Wayne from LET. So i'm sure if I get this set i will get another tune done by LET as well.
Old 03-25-2009, 08:48 PM
  #56
SPONSOR
loungn14's Avatar
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
definately want to do that....
Old 03-25-2009, 10:43 PM
  #57
JBFMCAR's Avatar
G63, 360CS, CLK63 BS, 997.2TT, 328D
I drive my car in South FL and we have 90 degree days all the time and i have not yet shut down from getting to hot. I have the Code 3, -10mod , and CM30 as my only cooling mods and will be doing the Tstat. Once you have these cooling mods with a 180mm and LET tune you will be good to go.
Justin
Old 03-26-2009, 12:53 PM
  #58
kipper215's Avatar
2004 E55 AMG
thanks for the response. I read your post about your lag issue and that's part of the reason I asked the question. I still want the car to be responsive and i don't want the car to run out of breath at the topend. I really would like to have a 7 inch core even if I have to make a special request. you cannot have enough cold air. the more cool air the better.
this will also make peak performance last longer.
Old 03-30-2009, 06:01 PM
  #59
D-5
D-5's Avatar
2003 E55
bought one @ $799!
Old 04-01-2009, 09:34 PM
  #60
chawkins2001's Avatar
2006 E55 AMG
they are charging $25 for shipping now, what happened to the deal?
Old 04-01-2009, 09:41 PM
  #61
SPONSOR
sales@eurocharged.com's Avatar
C63S
Craig - you know we wouldn't do that...you will only be charged $799.
Old 04-01-2009, 10:51 PM
  #62
bnzuovr's Avatar
2004 W211 E55K, GL550
i my self might be intreasted as well but also woudl like to see how much, diffrence in the sizes as far as performance and quaility. But i also would like to know how much a upgraded heat exchanger & tune would help?
Old 04-02-2009, 05:48 AM
  #63
2006 E55 AMG
ok, I sold my old setup and will get this one then. Thanks Jerry.
Old 04-02-2009, 05:50 AM
  #64
2006 E55 AMG
My ASP 175mm pulley that I sold weighed 13lbs. That is quite a bit more rotational mass right there.
Old 04-02-2009, 09:28 AM
  #65
JBFMCAR's Avatar
Yes the ASP is alot heavier since it's an OEM pulley with a ring welded on to it. Even just the stock pulley is heavier then the LET one. I wonder what gains there is to be had with less mass. I would assume more response and faster boosting along with more HP at the engine due to rotational mass. Maybe I will do a before and after dyno let180 vs asp180 with the same LET tune and then just a base tune.
Old 04-02-2009, 10:02 AM
  #66
01bolt's Avatar
01 lightning,05e55amg
LET 180 weight is 9 lbs
Old 04-02-2009, 09:42 PM
  #67
RonnieRenaldi's Avatar
SL55 AMG & BMW F10
Please do dyno LET180 vs ASP180, I really curious about the result
Old 04-08-2009, 02:14 PM
  #68
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
on order!!
Old 04-11-2009, 09:17 AM
  #69
BRABUS786's Avatar
Stage 3 63
hi
I have got a Brabus 168mm Pulley and would like to get a 180mm LET Pulley for more power.
Any Ideas? or shall i get a 175 or 172?
Acid
Old 04-11-2009, 09:22 AM
  #70
SPONSOR
loungn14's Avatar
Originally Posted by BRABUS786
hi
Acid
180mm with a heat exchanger and tune!
more power the better
Old 04-11-2009, 10:05 AM
  #71
BRABUS786's Avatar
Stage 3 63
hi
Problems is i will need to order everything from the US as im on the UK . lol
Where can i get a good heat exchanger?>?>? and a Tstatic>? and good places you can reccommend.?
Im getting 11.8 on the 1/4 im trying to get it down to the early 11s,
But the weather in the UK is rubbish for the 1/4 miles to much grit on the tracks.
thanks
Old 04-20-2009, 09:42 PM
  #72
Recieved my kit today.. Very nice piece! HAs anyone istalled theres yet? Impressions? Mines going in Friday..
Old 04-29-2009, 10:09 AM
  #73
SPONSOR
C63S
Ok guys!!
I got 10 more 172mm pulleys arriving today. I have 2 or 3 orders to catch up on, then the rest are ready to ship.
Don't wait, we will be going back to retail very soon.
Old 04-29-2009, 11:03 AM
  #74
Mercedes
That's an awesome deal for these pulleys! I loved my on my e55 !!
Old 04-29-2009, 11:32 AM
  #75
jng204's Avatar
2010 E63 AMG
Ok guys!!
Jerry,
Do you know if you'd do a group buy on the 180mm Pulley? I'd be interested in the 180 vs the 172.
Thanks,
Josh
Quick Reply: Eurocharged 172mm pulley group buy
