Eurocharged 172mm pulley group buy
Old Mar 20, 2009 | 10:56 AM
sales@eurocharged.com's Avatar
SPONSOR
C63S
Would anyone like to see a group buy for the Eurocharged / LET 172mm pulley kit?
What would the ideal price point be?
Old Mar 20, 2009 | 11:44 AM
jangy's Avatar
2015 S212
Can you give some details on it? I'd be interested because i'm not sure i like the huge 180 because of some lag. Also, I've seen plenty of tuned E55s with smaller pulleys put down great numbers.
Anything specifically special about this other than size?
Old Mar 20, 2009 | 11:48 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
https://mbworld.org/forums/w211-amg/...e-numbers.html
---from thread----
First pass with 172mm & Johnson CM30 installed and stock tune:
SAE Corrected: 418.45rwhp 443.17rwtq
Uncorrected: 423.96 449.01rwtq
After 3 more tunes to get it just right the end result was:
SAE Corrected: 470.97rwhp 498.23rwtq
Uncorrected: 479.27rwhp 507.01rwtq
Crazy numbers....
Old Mar 20, 2009 | 11:49 AM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
I am enjoying my 175mm pulley and LET tune. I am curious what the difference would be with a 172.
Old Mar 20, 2009 | 11:58 AM
aleksandar1099's Avatar
Top Answer: 1
Mercedes
You guys are in for a treat! I have been running the 172 for about a month now and it puts down serious power. It does not wobble at all and provides the same power as my old asp, but with less wobbling!!!
It also looks kick a$$ in the engine!!
Thanks again to let/eurocharged for all the help and great products!!
Old Mar 20, 2009 | 12:42 PM
jangy's Avatar
2015 S212
Any drive impressions between the larger asp and 172mm? Do you know weight difference between the two?
Old Mar 20, 2009 | 02:03 PM
Top Answer: 1
Mercedes
Hey Jangy,
To tell you the truth, I did not notice any lack of power changing from the asp to the LET one. I will be upgrading to the big daddy 180, and the power change will be noticeable with that one!!
The car drives very smooth with the LET pulley, but it also drove nice with the ASP, no drivability issues at all...
Old Mar 20, 2009 | 02:46 PM
jangy's Avatar
2015 S212
Hey Jangy,
I believe that a smaller pulley can put out as much power, especially as we leak boost.
I'm curious if you notice any quicker response from the motor with a smaller pulley. I have the VRP 180 one and noticed from day one that the larger pulley was causing some lag in initial acceleration. Once spinning, all is good and the boost helps. I just wondered if you noticed anything?
So, if you are going to a 180mm again, then why do you expect more gains out of it than the ASP?
Old Mar 20, 2009 | 02:49 PM
Top Answer: 1
Mercedes
Because I want to have the fastest e55
But seriously, I think that with a proper cooling system the power of the 180 can be had without issues...
EDIT: I did not have the 180mm asp, I had the older design...
Old Mar 20, 2009 | 02:50 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
i didnt realize that the 180mm would cause more lag.
if the smaller pulleys can make as much power as the larger 180mm then what would be the optimal pulley size?
i have the 168mm now but i would like to make more power. im just not sure what size to get anymore. i just assumed it would be ideal to get the largest one available (after cooling upgrade of course).
jagass's Avatar
pick up
I'm pretty interested here too...
Old Mar 20, 2009 | 02:54 PM
E55BKS's Avatar
A slow Tahoe!
Pulley & Tune
Count me in, but don't we need the tune with this pulley?
Old Mar 20, 2009 | 02:59 PM
E55Pilot's Avatar
2004 E55
And once again Not even Jangy understands what he's typing....
Seriously WTF does that mean?
Old Mar 20, 2009 | 03:08 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
im just brainstorming, but i assumed that it meant that the 180mm makes more boost than a smaller pulley but our cars leak excess boost so that increase in boost is not able to be used?
i remember in my old eclipse spyder over 10 years ago that the stock blow off valve would not hold much boost and that anything over a certain amount would just be leaked out, so once u change the blow off valve u are able to get more power right there because u can hold and use all the boost that the car was making. maybe its a similar situation to that.
once again im just speculating and trying to learn and understand as much as i can so that i can make a proper decision regarding a pulley upgrade. i wouldnt want to replace my kleeman pulley if there isnt much to be gained by doing so.
Old Mar 20, 2009 | 03:12 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Originally Posted by E55Pilot
...Seriously WTF does that mean?
You’re nothing if not persistent.
Pretty sure he’s referring to the ubiquitous bypass valve.
GL on the GB.
Old Mar 20, 2009 | 03:49 PM
lidas's Avatar
2009 SL 65 AMG
Also very interested.
Old Mar 20, 2009 | 04:59 PM
jangy's Avatar
2015 S212
No tail, only you don't get it. Pulleys are nothing new to the street scene. They may not teach about them in crop dusting school but that is your issue.
Spite never wins. As always, you attack without thinking things through. Now go ahead and correct me and add all the proper part numbers to prove me wrong and them fade from this thread like you do every other one that you try to attack me on. You think by leaving a thread when you are down makes everyone here forget?
You know, Tail. Some of us actually enjoy your banter because it gives us a good laugh from time to time.
As far as your question, ask Brad. He sure didn't hesitate to slap me with a warning for using coded curses and insults but you seem to have better luck.
LEARN HOW TO DRIVE and don't be such a sore loser.
Old Mar 20, 2009 | 07:30 PM
AZIPOD's Avatar
W211,E90,E66,E39,E38,NSX,Z32-TT
I did notice some lag when I had the 180mm put in. I can't say for certain though, but the feel of my pants told me that there was some lag.
Old Mar 20, 2009 | 09:46 PM
C32madness's Avatar
2006 E55
I think lag is the wrong choice of words here. I am sure what you are feeling is the heaviness from having to accelerate the mass of the supercharger faster. If you every converted a car from dual mass to lightweight single mass flywheel you would understand the concept.
Congrats on a strong setup.
I am digging the kleeman headers with stock pulley and tune. Got LET lined up to do the reflash next. Should be stronger with the tune.
Still waiting for someone to part with their 168mm pulley.
Old Mar 20, 2009 | 09:57 PM
TexasSteele's Avatar
2005 e55AMG
Would've been AWESOME 48 hours ago...lol
Just placed an order
Old Mar 20, 2009 | 10:12 PM
squidj's Avatar
2006 E55 (white); 2016 GL 550 (white)
So what's the price gonna be and how will the 172mm perform with the regular cooling system?
Old Mar 20, 2009 | 10:18 PM
III II I I AMG's Avatar
2003 e55
i am rlly confused... what i was taught as i was growing up is that smaller pulleys spins faster than bigger ones therefore it makes more power.... that's not how it works with these cars or was i mislead
Old Mar 20, 2009 | 11:51 PM
Timeless's Avatar
2005 E55 ///AMG
That would be true if this were the supercharger pulley...but this is the crank pulley.
Old Mar 21, 2009 | 12:18 AM
InTheBenz0's Avatar
GLC 63 S AMG / Corvette C8 / Jaguar SVR
Can someone from LET come in here and tell us the break down and the difference between a 172, 175, and 180 respective pulleys..
Old Mar 21, 2009 | 02:58 AM
E55Pilot's Avatar
2004 E55
with apologies to Chevy Chase Jangy you ignorant F**K. I've been playing with superchargers and pulleys since I could walk. My dad had a street rod with a 671 on it. Do you even know what that is?
what's your fixation with crop dusting? maybe because you're post are Cr*pdusting?
You have got to be kidding me, For once it would be nice if YOU actually thought something thru. But you don't and post wrong info anyway
Seem's that you're the one that pulls the disappearing act. You talk **** then never show up... Yup that's you
Nice try shortbus, you have that backwards, we are not laughing WITH you we are laughing AT you
LOL, STILL Can't answer the question. Typical Jangy, get backed into a corner and try for head fake, and then fail miserably
BWAHAAHAHAHAHAAHHH Still think you know who I am and what I drive. Jangy you are delusional. if you're such the driver why don't I ever see you at the track? I know how to drive and drive very well. I make a great side income private coaching drivers. what have you ever done?
