ticking noise from driver side engine bay
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Well I know a lot of members hear the knocking (ticking) noise from the v8 K…but mine has gotten a little bit more ticky…can I say that?
Tik tik tik tik form the driver side bank, the one that usually leaks.
What I want to know is, why has the tik tik sound gotten higher and what is it caused from?
If it is coming from DIRECTLY under the airboxes (towards the valve covers), it is probably a bad valve lifter or normal noise from the injectors.
When was the oil last changed as very dirty oil can increase lifter noise.
No way the plugs are going to cause a ticking noise.
will see if it goes away when i get it changed
thanks for the info guys!
V12-Biturbo
Good luck!
Have your heads checked. I hope its nothing other than a normal loud M113k but it sounds like lifter trouble to me.
How many miles?
I had the same kind of noise in my C63 from Day 1, but to be honest I haven't heard it that often since adding 1500+ miles on it.....I'll have to pay more attention.
It was a ticking "fan noise" or valve tick that I heard inside the cabin only at idle, most often in the garage, but also at red lights when stopped. Disappeared when on the gas.
yeah thats basically what i figured. That is one reason when the car is cold i usually let it wrm up for 5 or so minutes before pulling out of the driveway.
2003 E55 & 2014 GL550
I know there is a valve on the drivers side front that makes a ticking sound. Ken (my friend who runs the local Benz service) said he gets complaints about it all the time.
I'll ask him for the name of it but I have the same ticking sound. Can only hear mine at idle and listening close. Yours at all speeds?
'10 c63,'03expedition,ducati999,22'Donzi
guys, is the ticking coming from the block itself or from some other part of the engine bay? my car makes a clicking noise as well.but its coming from around the ABS unit. the mechanic at the dealer sad its a purge valve.
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
And yes I heard it from valve on the driver’s side front….the one that usually leaks on a lot of cars…Anyone found a fix to this by the way?
Scheduled for an oil change today, so will see how it goes inshalah (god willing)
Khalid
emm changed oil and flushed and changed again....tech heard the tick tick as i left ![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
says it could be lifters....car has 25k....
so what are my options and how much is this going to rape the modding stash![action](https://mbworld.org/forums/images/smilies/action1.gif)
bah
what are the dangers of driving and driving hard with noisy lifters?
bah
bah
bah
Your car is under warranty correct? 06 with 22k?
If not it could be pricey. If you go with replacing all the lifters and lifter seals it can get pricey.
It depends what they find is causing the issue. The car I was talking about also had issues with the rollers and cam shafts. That car needs 8500 in work and the owner is looking to just put in a new motor for 5k installed.
As for the damage caused by a bad lifter/seal varies. If it is minor it wont really cause an issue. If it is a pretty bad situation (where no oil is staying between the cam shaft and the lifter it will eventually wear the tip of the lifter causing it to become lose. After time the valve will drop out and fall into the motor. This is a worst case situation where the ticking is EXTREME.
I also know that when it is minor cars can be driven for 100k miles without an issue.
One way to see what the cause is would be to put in 15W-50 Mobil 1. That thicker oil will possibly keep the lifter pressurized (thicker oil wont drain out as quickly) and this could quiet it down.
I did this when a E320 daily driver I had with 100k miles (went back to 20w-50 factory fill instead of the 0w-40 mobil 1 I was using) and the lifters never made a sound again.
Like I said I have a friend going through this same thing with a NON amg car right now.
I have been doing them every 5k (intsted of 10k) with the recomended mobile 1 oil. Last oil change i think i only used 8 liters.
Any way i desided to go with a different recomended oil (castrol edage 10w 60) and got 8 liters of that. Also got 8 lit of 5w 10 just for flushing with the engien wash!
tech said the mobile 1 that came out was black, and the wash came out dark brown even after completre dranage & wash witht he other oil
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Filled it up with the new 10 w 60 and they said it was fine....
I desided to run a check oil level and saw it disply i needed 1.5 liters more (then it hit me i used to fill up with more then 8 liters in the past)
so i went and got some more to top it up until it said it was happy
Thing is they usuly recomend to run less due to our heat here..
could this have been the cause?
hmm how much oil do you you guys top up with?
tech said the mobile 1 that came out was black, and the wash came out dark brown even after completre dranage & wash witht he other oil![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Thing is they usuly recomend to run less due to our heat here..![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
That 60 weight oil is pretty darn thick but it is very good for seriously hard driving. If you run the car ragged for 1 hr straight that is a nice oil but for normal street driving it is a bit thick.
Now if the car is quiet again, that means your lifter seals are a tad weak. Since it is now staying presurized and quiet thats great. Just drive it and monitor the sound and oil consumption.
I have see M113k motors use about 1 quart each 1-3k miles.
As for doing oil changes, I think you can get a factory dip stick tool if you dont have a real dip stick on the motor. I cant recall but I swear these cars have dip sticks. I know my M156 does and I think my SL55 does. If it does use thats for checking the oil level as that computer thing is far from idea in my eyes.
I would switch back to 5w-40 next time to see if the sound comes back. If it does your motor will need some work one of these days.
Ok so I'm revisiting this thread because my engine has recently been experiencing unpleasant noises.
From what I can tell it seems to be coming from the passenger side of the engine, and it is a clanking noise. It doesn't sound healthy to be honest, but I can't say for sure what's causing it. It isn't noisy lifter noise. The noise is present at idle and under load and is present as soon as I start the car. I'm fearing something bad. I know I have a leak at both valve cover gaskets and I'm going to replace both of those as soon as I get home to the car... But I don't think it'll make much of a difference. The noise is present even immediately after an oil change. My car does burn a lot of oil too, at least it seems like a lot to me. I usually have to add 1-2 quarts between oil changes.
It's an 04, about 65k miles. Any idears? Naturally, no warranty coverage lol.
