W211 E55 Coilovers
Super Moderator
W211 E55 Coilovers
I recently went to buttonwillow with some friends and I fell in love. I thought to myself that I would LOVE to get my car out there but I knew there were ALOT of things holding back the car. One of them being the air suspension. I thought the car would handle a million times better with coils.
So here is my question. How many of you guys given that a coilover systems was available for our cars, would actually opt to go with coilovers in place of the air suspension? Just wondering if I'm thinking the same things as some of yall on here...
2015 S212
I disagree. The E will never be a buttonwillow car and coil overs won't change that. For a simple comparison, take a look at the handling between comparable setups on an E500 and an E350. The 500 has 30hp advantage and some TQ, but it is basically as close to a wash as we can find. the E350 is slightly lighter and has traditional suspension. Would the E350 honestly be faster than the E500 at buttonwillow? I'd argue that the active suspension would fair better on a more open course but any large car will be a chore on such a tight course.
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I was thinking about the same thing today. It is do able, electronics of the air suspension may be an issue.
A good staring point would be to upgrade the sway bars, this will dramatically reduce body roll which in turn will give you the feeling of a stiffer suspension.
1 Post
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
Strap some good triple adjustable coils on the E55 and it will make a HUGE difference dealing with the weight. Add some good suspension pieces to help dial in more negative camber and you have yourself a very competent handling sedan. Dealing with weight is difficult, but when you've got LOTS of mechanical grip, it tends to hide the weight in the corners. That doesn't mean it's not there, you just don't feel it as much and the car becomes much easier to drive quickly. The caveat to that is when it does break loose...you better know what you're doing as that much weight can be a handful. The CLK Black Series is a good example of this as it weighs almost the same as an E55.
02 996 Turbo, 05 CLK55 AMG
electronics should not be an issue you can simply select steel suspension...
It will make the handling better yes, but probably not what you're hoping for. There are many other suspension pieces that were not designed with optimum handling in mind and unless you address all of them, the shocks will only get you so far.
Super Moderator
Thanks for all the replies thus far guys. I'm not trying to be a full on track guy with the car. If I was, then I would have bought another car.
BUT
I thought it was a start. Start with coils and then do sways after. Then do the lil things after that. I'm just lookin for something a lil more "sturdy"...
Crawl, walk, run...
BUT
Crawl, walk, run...
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Victor (VRP) was going too go down this road I think he abondon it. Untill someone installs a coil over on al four corners. No one can say that it will be better, till its on the skid pad and it proves out.
I have had Airmatic problem and did consider a conversion to coilovers.
But I need to be able to adjust my ride hight on the fly.
Sun,
Actually, the bigger problem you will have is not with suspension (which is a problem) but it's weight. Weight trickles down to everything... braking, suspension, etc. There have been people crazy enough to track their 55s but most of them complained about brake fade more than handling. Your car is also modded and while I know you did a cooling package, with all that extra power I am curious how the car would hold up with multiple hot-laps at a track like buttonwillow.
-m
-m
1 Post
Sun,
-m
-m
2015 S212
I looked into sway bars and even had a shop that was willing to make them for about $500, but they needed the car for a week. Turns out we have 45mm fronts and 40mm rears (I think). I gave up since that was already so fat. Does anyone that understands better than I feel this is worth looking into more?
Super Moderator
Sun,
-m
-m
I am taking steps to alleviate weight issues as well. Upgrading to the Evosport rotors soon, gettin new wheels (lightweight forged one piece for the track) + R compound tires, and trying to lighten up the interior a lil
Once again, I'm not tryin to go ALL out but I want to do what I can to make it quick. I know it won't be as fast as other track dedicated cars, but I want to be able to enjoy the car at the track once in a while also.
As far as everyday driving (which I do), I don't mind not having air suspension.
Excellent point, but there is nothing curious about it. As you said, the brakes would need to be upgraded as well to make it "safe". Of course if you don't plan on really pushing it on the track the stock setup is adequate - but not for any extended periods of time under track duty... Running a street car on the track hard tears things up in a hurry if they are not built for it. Just going to coil overs will make a big difference, but as I mentioned before, shocks can only do so much and you would need start changing out suspension pieces to realize the full benefit of coil overs.
Sorry for the misunderstanding - I was referring to the motor, with IATs/coolant possibly becoming a problem after so much back to back WOT. Obviously, higher entry speeds because of the extra HP will also attack the brakes more so than with stock HP levels, but I'd be curious how IATs/coolant temps would look after a few laps with pulley/tune/etc - essentially if the heat exchanger is capable of doing it's job outside the street/dragstrip.
-m
Super Moderator
Thanks again to all the responses. I'm just a n00b and fellow car nut trying to learn something new everyday .
Thanks to all the guys that contributed and who are about to contribute!
1 Post
Luke,
-m
-m
Super Moderator
I saw that thread a long time ago. What I'm talkin about is getting rid of the air suspension completely and going coils. I don't want a hybrid suspension like that is.
Air is nice for comfort, but when pushed, I don't think it can hang with a coilover system. Just my 2 cents.
Sun,
-m
-m
While weight is a problem, it CAN be addressed through the suspension, rather than trying to go on a diet. Look at the new CTS-V, it handles better than a lot of sports cars, and it's just as heavy as our AMG's.... This is because it's suspension was purposely designed; not just shocks and sway bars, but every single component, down to bushings.
Anything is possible. It is possible to put a V12 in a new c-class, it is possible to make a festiva a track car, anything is possible with enough time and money. My point was just to speak to fundamentals. A CTS-V weighing 3000lbs will perform better than a CTS-V that weighs 4000lbs. At the track weight will become your enemy, regardless if theoretically you could reengineer the entire chassis to deal with it better -it is fairly obvious that is neither feasible nor plausible in the context of this discussion.
-m
1 Post
A4, M3, 996, E55
While I'd love to see coilovers as a suspension option on the market for the E55, I can't say I'd actually buy a set. Track was just not what I bought the E55 to do. I've got two other track prepped cars in the garage for that.
Andy
Andy
Bob,
-m
-m
All I'm trying to point out is that of the two issues, one is easier to address than the other
